| CANADA Canada |
#29 |
#30 |
Drives: GT-86
I should have added we only have e10 91 octane where I am. Shell vowed is what I usually use
#31 | |
Drives: '14 Subaru BRZ
Life's too short to drive a boring car
#32 |
Drives: '13 Whiteout FR-S (M/T)
I can respect that, it's a trade off between two evils but I'd rather take ethanol, which isn't proven to harm the system vs. Knock, which is blatantly bad.
#33 | |
#34 |
Drives: Black on Black on Black
just had my original pump replaced in june with what I assume to be their most recent and have crickets still. exclusively us shell 91
#35 |
Drives: BRZ Sport-tech
I ran Shell 91 exclusively from June 2013 to June 2014 and I had crickets basically the entire time. Not sure how all the others claim to have no crickets. IIRC it's a May 2013 build date.
I'm now doing 1 year on Petro94 exclusively. I can say for certain that that the crickets are RIDICULOUSLY worse. But I know for sure that I had them before. |
#36 | |
Drive From Home
Drives: BRZ STI Performance
Isn't Subaru IAM value range 16? |
#37 |
I'm on aftermarket now but even on stock back in the day, you can hear the tip-in known happen under high load between 2-3K RPM. The stock tune isn't optimized for 91, it's 'safe' because your IAM will drop to adjust timing for the lower octane to counter the knock as best as it can.
| The Following User Says Thank You to 1Cor10:23 For This Useful Post: | krayzie (07-18-2014) |
#38 | |
Drive From Home
![]() We need Chevron 94 E0 here in Ontario.
#39 |
Drives: 2014 BRZ Ltd - DGM
They're likely never going to eliminate the crickets, I believe they've revised the fuel pump as many times as they are willing to. Just read another thread where user brought car in for updated pump, crickets came back, dealership called tech rep from Subaru and official position from Subaru is now that the noise is normal and there is no further fix.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
#40 |
Drives: 2014 Subaru BRZ Limited 6smt
So how many people have gone aftermarket to fix the crickets, and to get more fuel flow for potential upgrades further down the line?
My dealership has a new pump on hand for me but I don't want to leave my car there for a whole day just to have the same problem again, or potentially worse, since my crickets are irregular and are not always present. |
#41 | |
2014 BRZ Ltd. - DGM
#42 | |
I know Full Blown has one and im sure others do. I might start a thread and ask about it. |
| Changing fuel stops the chirp | wbradley | Issues | Warranty | Recalls / TSB | 101 | 07-07-2014 04:46 PM |
| Dealer says power steering pump responsible for chirp | joelg | Issues | Warranty | Recalls / TSB | 10 | 11-03-2013 08:54 AM |
| Fuel Pump high pitch chirp noise | lucius | AFRICA | 9 | 10-24-2013 02:40 PM |
| i hope the look of the frs doesn't change too much throughout the years... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 11-07-2012 01:21 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
