Old 02-04-2014, 08:09 PM   #29
Nasty Sausage
Nasty Sausage's Avatar
Drives: '13 Asphalt FRS 6MT, '04 IS 5MT/LSD
It would be neat to swap in a stock TT Aristo motor 2JZ. It has accommodations for cruise control, traction control, and the electronic throttle sensors, in addition to the cable. From doing research, and since my IS also has the later Supra/Aristo hybrid cable/electronic throttle system, I've come to find out that the electronic sensor is to achieve the same amount of energy produced going uphill as well as downhill, so your car will accelerate the same uphill as in downhill. It automatically increases and decreases the throttle position given the same input depending on elevation. Interesting tech. I wonder how this can be applied to the twins.
Nasty Sausage is offline   Reply With Quote
Old 02-05-2014, 10:29 AM   #30
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Macklin View Post
Hello
Curious what you are doing for the drive by wire? are you going to convert to cable?
Undecided at the moment. Looking at a standard cable system though.
The drive by wire is still manipulated by a cable in the "drive by wire" 2JZ-GTE. The build is taking a lot of turns lately. There was a slight miss-communication and I'm looking into a live axle setup. I don't do twisties so the purists are REALLY going to hate my car.
In any case, the heads are coming off and a set of GSC S2's, Beehive springs/Ti retainers and new valve stem seals are going in.
I plan on pulling the FA20 in April after we move into our new house and it should be a fun build.
slicktop is offline   Reply With Quote
Old 02-05-2014, 06:17 PM   #31
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Looking forward to the 2jz build. I'm a twisties person but your car is going to make for a badass street/strip toy! 9 sec car and driven to the track.
hmong337 is offline   Reply With Quote
Old 02-05-2014, 06:19 PM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
A 2j can be built for the track too
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
slicktop (02-05-2014)
Old 02-05-2014, 08:20 PM   #33
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Sent from my IBrick
Yeah, but the solid axle sorta takes away from that.
To the OP: Please do a proper long arm suspension with decent triangulation. It will make it that much better to drive down the street and will help control the power. I am sure there has to be drag forums that cover proper suspension setups, but coming from the Jeep world, I have some buddies who have built their own suspesions and there are geometry calculators that can calculate things like articulation, COG, wheel hop, and the like so that you get the best possible setup.
Luckrider is offline   Reply With Quote
Old 02-05-2014, 09:48 PM   #34
slicktop
I have a few very very knowledgeable friends that I will be working with to make this all come together. We'll be nailing down specifics very soon.
Just got back from the machine shop earlier today and I'm looking at a fun setup
The Following User Says Thank You to slicktop For This Useful Post:
Luckrider (02-05-2014)
Old 02-05-2014, 09:48 PM   #35
RRBS
Drives: 2013 Raven FR-S
Originally Posted by glorydays View Post
So what's the reason why the vvt engines won't work with these? Is it a clearance issue or do they mount differently? Also what other transmission options are there because a getrag seems cost prohibitive for most. It seems most 2jz come auto.
VVTI is front sump that is why it has fitment issues.
Good luck with your build.
RRBS is offline   Reply With Quote
Old 02-06-2014, 12:23 AM   #36
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
only aristo 2J's are front sump. JZA80 vvti engines are rear sump
JP is offline   Reply With Quote
Old 02-19-2014, 07:50 PM   #37
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Cool
Bad ass! I have found a fellow 2JZ FT86 brother lol. I just picked up a BRZ and recently joined this forum. My build has been on the low but I will cameo the venture in this thread. I went with the Xcessive Engineering 2JZ FT86 engine mount kit as well.
If you are already in the engine, you might as well do the heads. I replaced the water pump, timing belt, pulled the heads (Stage II PnP) and also went with the GSC S2s mated with the Beehive springs. Heads are fully built along with the bottom end. Don't forget about the billet modified oil pump, billet tensioner, and damper. I went with an ATI super damper crank pulley. I have the V160 6-speed trans with a ATS triple carbon clutch. Still trying to decide on the rear-end and the DS will of course come from the Driveshaft shop. More details will be in my build thread which will be created once I drop the engine in.
Which intake manifold are you going with slicktop? I went with a Virtual Works with a 90mm TB.
Time to share some photos:
If you or anyone else needs some help/advice with a 2JZ build, please give me a shout. I would be glad to help.
You can always swap out the oil pans if need be.
2JZ Front sump oil pan VS. 2JZ Rear sump
Drift&Drag is offline   Reply With Quote
The Following 3 Users Say Thank You to Drift&Drag For This Useful Post:
inertia (08-17-2014), normancw (02-19-2014), xia (02-19-2014)
Old 02-19-2014, 08:05 PM   #38
slicktop
Always great to hear from another guy doing the swap! My motor was dropped off yesterday at the machine shop.
Preliminary details:
10:1 CP Pistons
Carrillo H-beam rods w/ CARR bolts
Pro-Gram mains
ARP fasteners all around
GSC S2
GSC Beehive w/ Ti retainers
GSC Valve guides
GSC Valves (stock size)
GSC VSS
I'm sticking with stock throttle body at the moment because I know it can support four digits. I have the PHR modded oil pump and MVP billet tensioner w/ Gates belt. There's a possibility of some more stuff happening but it's up in the air at the moment.
I'm going with a custom rear end setup. No details on that yet, but I'll definitely keep you in the loop!
Old 02-19-2014, 08:09 PM   #39
SmsAlSuwaidi
Boosted
@slicktop @Drift&Drag
i hate you guys so much
Drift&Drag (02-19-2014)
Old 02-19-2014, 09:15 PM   #40
slicktop
GTX4202R
Old 02-19-2014, 09:16 PM   #41
SmsAlSuwaidi
Boosted
GTX4202R
T51r
Sent from my IBrick
Old 02-19-2014, 09:16 PM   #42
slicktop
T51r
Sent from my IBrick
On the FA20?! YES
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
New Here and my go pro mount hegreer1 Scion FR-S / Toyota 86 GT86 General Forum 11 09-19-2013 06:02 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 02:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 11:58 AM
Plate mount Nat CANADA 32 08-26-2012 12:18 PM
