Old 03-07-2024, 12:50 PM   #29
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by dragoontwo View Post
I'm going to guess that the only difference is the added plating on the parts that contact the aluminum hub. If you check the new car information in my sig it is on pg 250.
ooo good point, thank you! I've ordered a first gen hub since Subaru has no second gen hubs, I'll update here if it works.
Old 03-09-2024, 06:05 PM   #30
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
First gen front hubs bolt right into a second gen and work perfectly fine. I replaced mine with a Timken which is *much* chunkier. Time will tell if it holds up better.
Old 03-19-2024, 11:35 AM   #31
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
For funsies, I replaced the other side wheel bearing bearing with an SKF since that side was also trashed. Looks the same as OEM.
Now we race to see which brand needs to be replaced first, haha.
Old 03-19-2024, 01:16 PM   #32
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
So the rear takes 20 min to swap- how bad is the front? Same?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 03-19-2024, 01:21 PM   #33
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Are you guys finding aftermarket wheel bearings are lasting longer ? Price wise hubs from toyota seem to the same price more or less
autoracer86 is offline   Reply With Quote
Old 03-19-2024, 03:29 PM   #34
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The rear is more work than the front. The most time consuming part is swapping the studs, haha
Old 03-20-2024, 11:05 AM   #35
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Has anyone tried MOOG hubs?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
TOB life expectancy Sniepster Issues | Warranty | Recalls / TSB 48 10-23-2022 11:36 PM
front wheel bearing life ZDan Tracking / Autocross / HPDE / Drifting 18 06-18-2019 11:38 AM
Average life expectancy from Tein Basics? HatchirokuV2.0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 12-11-2015 08:24 PM
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 04:57 PM
Wheel Bearing Woes jwstaton Issues | Warranty | Recalls / TSB 16 01-24-2014 08:06 PM
