Old 02-04-2024, 11:23 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Wheel hub bearing life expectancy?
Any insights regarding front &/or rear wheel hub durability in track driven 86’s using 200 tw tires and improved suspension with high camber (-5,-2)?
And, is there a hub which would be better than an OEM replacement?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 02-05-2024, 10:12 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Mine all lasted more than 100,000 mi.
Sent from my Pixel 7a using Tapatalk
Old 02-05-2024, 09:23 PM   #3
whataboutbob
AutoX-10/10ths every run
I preemptively replaced my rears about 110K, need to check my fronts for slop at some point, at about 128K on those.
Build thread:Here
Old 02-05-2024, 11:49 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
OEM worked best for me. I tried a couple off brands I’ve been through a handful of fronts and one rear.
Old 02-06-2024, 12:02 PM   #5
RedReplicant
Drives: None
I lost the front left at like 33k miles on the chassis so I replaced it with a Timken. That one lasted about ten events before making the tell-tale marbles in hollow can noise when spinning so I replaced it with a Centric. Centric has been fine for about 30 events now.
I got a good deal on OEM fronts so I currently carry an OEM front and an OEM rear as spares.
RedReplicant is offline   Reply With Quote
Old 02-06-2024, 12:43 PM   #6
Muskoka800
Thanks, and keep the info coming folks!
I’m only at ~86,000 kl (~53,000 miles) mostly DD so may be good for some time.
Old 02-06-2024, 02:25 PM   #7
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I don't want to jinx myself, but I'm at ~43k miles on a 2017 with mainly heavy autocross usage. Probably about 665 autocross runs from my records (about 110 events). 200TW tires, stock suspension, stock wheels/offset. Wheel bearings appear to be still just fine.
cmiovino is offline   Reply With Quote
Old 02-06-2024, 08:52 PM   #8
SuperSub7
Drives: Awesome
lost my rear hub at 33k miles and replaced it.
SuperSub7 is offline   Reply With Quote
Old 02-07-2024, 01:15 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’ve had a bad front sitting on my bench as a paperweight I have been meaning to cut in half for years. I am kind of curious what the bearing size is and if the grease just isn’t up to snuff. It seems like track cars kill them a lot faster.
Old 02-07-2024, 10:13 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
The fronts on my 2017 only lasted one track season, 12 track days! Had them replaced under warranty Setup that year wasn't great, stock struts and lower springs combined with camber plates kind of over-lowered the front such that it was on the front bump stops just sitting. Tremendously overloaded the outside front in cornering...
Old 02-07-2024, 12:18 PM   #11
86league
Drives: '13 BRZ Limited
I got 50k and 30+ track weekends on my 2013 before the fronts needed replacing. The 2020 only went 11k and maybe 8 weekends before a rear was done, and both fronts followed shortly after at about 15k and maybe 3 additional weekends. Friend went ~5 years and 40+ (?) weekends on a 2019 before needing a rear. So, it it's pretty variable.
I think with lots of camber, 200tw tires, and driving to the limits of the car -- 8 weekends is unexpectedly early, but 30 or 40 weekends is overly optimistic.
Those were all OEM and street-driven as well as track. How many hard hits from curbs/potholes/etc each took is sort of impossible to know.
86league is offline   Reply With Quote
Old 02-07-2024, 12:38 PM   #12
RedReplicant
Drives: None
Dropping wheels hard has been the number one killer of wheel bearings across track cars for me. Not the normal curb hits, the ones that make you wonder if half the car broke off.
The Following User Says Thank You to RedReplicant For This Useful Post:
CSG Mike (02-08-2024)
Old 02-08-2024, 09:46 PM   #13
Wheel bearings are not a normal replacement item for this platform, and strictly "as needed". It's not common without reason.
Old 02-08-2024, 11:33 PM   #14
jflogerzi
jflogerzi's Avatar
90k 3rd owner on a modified 2013 only driven on track now. all seem good so far
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
TOB life expectancy Sniepster Issues | Warranty | Recalls / TSB 48 10-24-2022 12:36 AM
front wheel bearing life ZDan Tracking / Autocross / HPDE / Drifting 18 06-18-2019 12:38 PM
Average life expectancy from Tein Basics? HatchirokuV2.0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 12-11-2015 09:24 PM
Wheel bearing? Nylander Issues | Warranty | Recalls / TSB 20 06-08-2015 05:57 PM
Wheel Bearing Woes jwstaton Issues | Warranty | Recalls / TSB 16 01-24-2014 09:06 PM
