Old 03-23-2022, 12:08 PM   #29
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by churchx View Post
I wouldn't consider similarity to stock as any kind of pro, rather opposite, as stock header for several prioritized reasons, like emissions, mass production cost, clearance, might be more compromised then aftermarket parts with performance as main goal.
Characteristic subaru-ish UEL was not put there on many subbies for specific sound. Design was chosen such to reduce material used and cut costs, with worse performance compensated with more boost. I'm sure, that there are many compromises with stock twins header aswell, such as below optimal runner lengths, too wide merge angles and such. Different priorities.
I love all the hate I get when I tell people this.
If UEL was/is so good then why don't any pro race teams use it.
The Following 5 Users Say Thank You to x808drifter For This Useful Post:
churchx (03-23-2022), grumpysnapper (03-24-2022), NoHaveMSG (03-23-2022), p1l0t (03-23-2022), Tatsu333 (03-24-2022)
Old 03-23-2022, 12:42 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Constant myth perpetuation over decades is hard to erase.
Old 03-23-2022, 12:47 PM   #31
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The general public loves to be annoying douchebags.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 03-23-2022, 05:03 PM   #32
p1l0t
p1l0t's Avatar
I just love the sound it makes. You can tell a Subaru from a mile away. EL probably is better but I love my Tomei headers (on my STi my BRZ is stock)
x808drifter (03-23-2022)
Old 03-24-2022, 04:49 AM   #33
saltywetman
Drives: 2020 Toyota 86 GT 6M
another note regarding the apexi header is that it comes as a set with the OP and FP and since the FP has a fairly large resonator on it, it makes for a much quieter setup even compared to stock when pairing with various aftermarket catbacks @mav1178 posted an in depth review here https://www.ft86club.com/forums/showthread.php?t=103338
I personally run this kit + fujitsubo catback and it's quiet enough that I don't get harassed by cops
saltywetman is offline   Reply With Quote
The Following User Says Thank You to saltywetman For This Useful Post:
gpvecchi (03-24-2022)
Old 03-24-2022, 02:07 PM   #34
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by PulsarBeeerz View Post
Look closer, they are both 4-2-1. One should run insulation on the oil pan regardless of header design.
Shouldnt it be the other way around? Insulation on the header (wrap, coating or other) and let the pan the way it is? Pretty sure that covering the pan in insulation material just prevents the oil from shedding some heat there.
Old 03-24-2022, 03:53 PM   #35
norcalpb
norcalpb's Avatar
Yes ideally you want to ceramic coat the header. Keeps heat away from things like the oil pan and coil packs, but the hotter your manifold the higher the exhaust gas velocity from what I can remember.
Old 03-24-2022, 04:12 PM   #36
gpvecchi
gpvecchi's Avatar
I hope it will be quiet with my STi axleback...
gpvecchi is offline   Reply With Quote
Old 03-24-2022, 05:59 PM   #37
Celica00
Celica00's Avatar
Drives: 86
The top one because it reminds me of the headcrabs in Alien
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
p1l0t (03-25-2022)
Old 03-24-2022, 11:44 PM   #38
PulsarBeeerz
Drives: JRSC BRZ SOLD
I've always run it on both. Reflective insulation on the pan prevents head from soaking into it..
PulsarBeeerz is offline   Reply With Quote
Old 03-25-2022, 04:42 PM   #39
grumpysnapper
grumpysnapper's Avatar
Yeah I tend to agree, and with a good wrap, it’s amazing how much heat is kept in the manifold, which aids the exhaust gas flow.
IMHO ceramic coating is a relative waste of money compared to wrap. Plastics were still melting near the headers after I had mine coated… but you can almost touch the headers after being wrapped. (But wrapping is a pain in the butt, and needs upkeep)
grumpysnapper is offline   Reply With Quote
The Following 2 Users Say Thank You to grumpysnapper For This Useful Post:
Icecreamtruk (03-28-2022), p1l0t (03-25-2022)
Old 03-25-2022, 05:26 PM   #40
gpvecchi
gpvecchi's Avatar
Isn't wrap risky if it gets soaked in oil?
Old 03-25-2022, 06:53 PM   #41
p1l0t
p1l0t's Avatar
Not the wrap itself, just the oil that gets trapped in it...
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
gpvecchi (03-26-2022), Icecreamtruk (03-28-2022)
Old 03-26-2022, 12:26 AM   #42
saltywetman
it will. according to the review by mav, it made even the blitz nur spec catbacks quiet!
p1l0t (03-26-2022)
Best manifolds (headers) to OFT - OpenFlashTablet petermmdk Engine, Exhaust, Transmission 14 02-09-2021 02:01 PM
RHD/LHD Manifolds secret.squirrel Engine, Exhaust, Transmission 4 03-11-2016 03:31 PM
FA20 Aftermarket Intake Manifolds slava Engine, Exhaust, Transmission 13 03-20-2015 09:49 AM
EGT or O2 logging with UEL exhaust manifolds? burdickjp Engine, Exhaust, Transmission 0 01-23-2015 03:46 PM
Performance manifolds Nitro_FRS Engine, Exhaust, Transmission 20 10-17-2013 12:42 PM
