Old 10-31-2020, 07:33 AM   #29
Maxhouse97
Drives: Looking
About right TommyW I have thought Elise too, but am thinking a bit fragile for the track, quirky, and super expensive to fix body panels in addition to getting in and out of.
Tcoat also agree with you. This was the center of my question, although I’m encouraged by a couple of the responses here. I had LWFWs on other cars and they do seem to make a big difference.
How’s do the post 2017 changes effect the engine relative to what we are talking here? Difference or hardly noticeable?
I am impressed by the community here ... big factor for me as well.
Maxhouse97 is offline   Reply With Quote
Old 10-31-2020, 09:27 AM   #30
I had a 14 FRS and now have a 20 86. The engine changes are not even noticeable other than I have never had crickets. What is noticeable is the changed final drive ratio. The 86 has a slightly better jump off the line. It doesn't all of a sudden turn into a Hellcat or anything but it is a very slight improvement. The trade off is a minor reduction in highway mileage but is small and worth it.
The best bang for the buck is to get a tune that does away with the factory compromises they are forced to have due to emissions and mileage requirements. Some say a header is needed but the car already has a header so changing to a different one is not going to net you much "improvement". Will make it sound cooler though!
Some of the other things mentioned will change how the car feels and maybe make it marginally "faster" but it will still be a 2 lite ... ahhh you get that point by now!
Old 10-31-2020, 10:12 AM   #31
alphasaur
friendly
Drives: 17' 86
Originally Posted by therealstoly View Post
I sometimes sit here in disbelief at how tolerant this forum/community is. Try joining any other forum for any other platform just to ask a question that has been answered, debated, and otherwise discussed for nearly a decade and see how that pans out...
Address the air in and out of the engine, add a tune, and there you have it.
I picked a 2020 BRZ over several other options, including the ND, for a variety of reasons that I don't often see mentioned. I've had three Miatae and other Mazdas and couldn't bear to have another Mazda I had to argue with every single time I fire it up.
I would argue that the BRZ is the rawest driver car you can get in 2020. The Mazda consistently thought it could outdrive me between lane assist, which was worthless, adaptive cruise control, which was problematic, et al. If you want a car you drive, the BRZ is about as close as you can get to the 'good ole days' with a factory warranty. A now mandated rear view camera, which I'm a proponent of, ABS, airbags, and that's really about it. It doesn't have a heads up display, yell at me, and in the case of Mazda, vibrate and jerk the wheel every time it confuses itself as onramps turn into interstates with the sun at an angle.
It's a driver's car without a lot of the nonsense that needs just a little help with its lung capacity from the factory. And I would also tout the community that the BRZ has in comparison to any other forum I've been a part of.
I've owned an NA, speed 3, two speed 6's, Mazda 3, cx5 and cx9 and I never had reliability issues that I didn't cause (supercharging, big turbo etc).
Consumer reports seems to agree that Mazda is currently more reliable than subaru and is led only by toyota/lexus.
You can also disable lane assist.
In regards to it just being a two liter NA engine, in my experience this car actually picks up a fair bit of power for an NA car from easy mods. A header and tune can net ~25-30 whp and add e85 for another 10 or 15. NA cars typically don't make much more power with mods.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 10-31-2020, 11:05 AM   #32
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by nikitopo View Post
What adds character to a NA engine? A flat torque curve? This I would say is more of a turbo thing. A rev up to 8000 rpm? Too difficult to be achieved in this engine. Much more power? Then I am afraid that you'll need to go FI and you lose the NA aspect. Maybe adding just sound? It depends on user priorities and the term 'character' is a different thing for different people.
For me adding character is all the small things that you can add up to make the car a bit better, but in this case I would say to not focus just on the engine. In fact, the engine might be an area that you should focus the least. Especially, if you want to stay legal with emissions and you have an environmental awareness. CSG Mike gave an example of other areas like a light clutch assembly.
yes in Calif at least, a header and tune won’t pass emissions so every 2 years you have to return to stock for smog testing
Old 10-31-2020, 11:46 AM   #33
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The only detriment for the twins are the bench racers who have never driven one all shouting "MORE POWER!!!!!!".
It goes fine for what it is. Momentum over 1/16mi digs.
2 or 1.6 stock engines are not normally drag race champions.
They've done just fine over the years of Monte Carlo rallys, routinely beating much heavier cars with giant engines.
Old 10-31-2020, 01:38 PM   #34
TommyW
TommyW's Avatar
Correct. It depends what you want the car for. Some of the kids that just want a stoplight racer that will never see the track should buy something else.
My philosophy on the track is a monkey can push a gas pedal on the straights. If you're a driver then the straights are just a wait period for the next turn.
If you're a track driver and just want the thrill of speed on a long straight and see turns as things that are just in the way before the next straight then get a different car.
What is that saying? Something like "Straights are for fast cars and turns are for fast drivers"?
Old 10-31-2020, 03:21 PM   #35
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I have a 2018 ts that was e85 tuned with a Q300 catback and it was OK. The PSR UEL header install was next,uel for sound. This, now final power(LOL) mod, really had the most noticeable effect on the cars pick up. It pulls better from 2k all the way ro 6.75 then gives a surprising surge to 7.5k. Placebo?, sound? You can`t hear it with the windows up after 2nd except for that sound tube thing that must go.
gen3v8 is offline   Reply With Quote
Old 11-01-2020, 12:53 AM   #36
How do you figure you can get 25-30 with a header and tune? Maybe 10 or 15. The bigger possible gain is the E5 but that is not an option for everybody.
Old 11-01-2020, 02:15 AM   #37
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
E5? Our Shitty fuel is E10. Going to run the E85 out of mine and try the 98 seen as I did not run it first
Old 11-01-2020, 05:01 AM   #38
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
@bcj Lol! I like your pic. @Tcoat ?
Old 11-01-2020, 06:31 AM   #39
Turdinator
Señor Member
Turdinator's Avatar
It could be argued that engines with character usually have lumpy torque curves. The flat torque curve people look for tends to be boring. Engines with vtec style setups or turbos that boost suddenly tend to feel more fun as you have to keep them in the sweet spot and the transition from low torque to high is exhilarating.
I suspect if Toyota/Subaru had tuned the fa20 to not have it low rpm torque and just been flat until ~4.5k where it currently comes out of the torque dip more people would like it’s feel
1974 TA22 Celica
2013 86 GT
Old 11-01-2020, 07:53 AM   #40
pallen
pallen's Avatar
Drives: 2017 Toyota 86
I have a 2017 86. I did the headers, flexfuel and a tune. It makes a difference and I’m pretty happy with the car now. It’s not a night and day kind of difference like a turbo or other FI, but it’s a solid bump in feel and I don’t feel like I’ve done anything to hurt reliability of the car much. This is still not a “fast car” that the stoplight racers would be proud of. The next mod is tires. My car came with some brand new, terrible tires and I’m to cheap to just replace them.
pallen is offline   Reply With Quote
Old 11-01-2020, 10:46 AM   #41
typo
Old 11-01-2020, 10:58 AM   #42
alphasaur
friendly
Drives: 17' 86
Stock dynos 165ish and header and tune dyno is the lower 190/upper 180s from what I have seen
https://www.ft86club.com/forums/show...&postcount=224
https://www.ft86club.com/forums/showthread.php?t=130575
Here's a link I googled quickly which seems to corroborate it, dunno? That's pretty consistent with most of the numbers I've seen. Maybe I'm wrong? Feel free to post evidence.
F/S FA20 engine wooly35 Engine, Exhaust, Bolt-Ons 0 07-19-2017 08:11 PM
WTB: FA20 Engine leets4uc3 Want-To-Buy Requests 0 03-02-2017 11:29 AM
Easy 5lbs out of your engine bay. Wonderbar DIY (Do-It-Yourself) Guides 14 03-28-2014 12:55 PM
How easy to work on boxer engine? civdaddy Scion FR-S / Toyota 86 GT86 General Forum 5 02-03-2013 07:22 PM
