Old 02-03-2013, 04:52 PM   #1
civdaddy
Drives: Slow
How easy to work on boxer engine?
My first car was a 03 civic si and being a Honda it didn't need any engine work, but at 100k I adjusted the valves because I was bored and wanted to learn how to do it and I'm not that mechanically inclined. My last car was a 2.0t genesis coupe and that was a easy car to work on as we'll.
How hard would adjusting the valves and doing spark plugs on this car be?
What are some maintenance jobs down the road that will be a pain or cost alot to have done?
civdaddy is offline   Reply With Quote
Old 02-03-2013, 05:11 PM   #2
D1cker
Drives: B9 S4/ND2
everything on this car EXCEPT the spark plugs, is easy.
The spark plugs on the other hand are going to be a righteous pain in the ass.
D1cker is offline   Reply With Quote
The Following User Says Thank You to D1cker For This Useful Post:
Synack (02-04-2013)
Old 02-03-2013, 05:24 PM   #3
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
The location of this motor in the car (really low) is going to make it much harder to work on in those two regards compared to any I4 motor. The factory manual actually has spacers to put in place on the engine mount points to raise it up to do a spark plug change. I'm sure people will find quicker ways to do it as the 60K mark approaches, but expect a tougher time in regards to work on/around the head.
Now, the timing chains and accessory belts are (obviously) much easier to work on due to being right at the front of the motor. I've changed a belt and cam seals on an EJ20 and it was SUPER easy compared to any of the Honda motors I've worked on. Pop out the radiator and have easy access to the entire front of the engine. The timing components of the FA20 look a lot more complex than an EJ, but I think the access will be similar.
I have all the shop manuals I could find (Shop, Trans, Engine, Wiring) located in a google drive folder, feel free to view and download:
https://docs.google.com/folder/d/0B6...it?usp=sharing
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following User Says Thank You to Superhatch For This Useful Post:
kthxbai (02-04-2013)
Old 02-03-2013, 05:28 PM   #4
civdaddy
Drives: Slow
Thanks for the link!
Old 02-03-2013, 05:30 PM   #5
civdaddy
Drives: Slow
I just wanna know what I'm getting myself into because il be out of warranty very fast with how much I drive.
Old 02-03-2013, 07:22 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
plugs, cams, pistons, anything around their will be hard.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
What happens on a Boxer engine when there's too much Oil? @Art_Mighty Engine, Exhaust, Transmission 29 06-15-2014 04:36 PM
What makes the Boxer engine so special ZakD Scion FR-S / Toyota 86 GT86 General Forum 111 11-02-2012 09:54 PM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
