Old 03-22-2014, 08:04 PM   #1
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Easy 5lbs out of your engine bay.
Gents,
So I was poking around today seeing what pointless brackets or random things I could pull out of the engine bay, when the black stamped steel covers for the fuel rails made eye contact.
Each one is held on my two 12mm bolts, one on the front and one on the rear. These seem to serve absolutely no structural purpose other than to protect the rails from clumsy mechanics dropping hammers.
The passenger side one does hold up the injector controller, but I've got an easy, cheap and DIY solution.
If you have a drill, a grinder and something to cut a straight line in aluminum with, all you need is some 1/2 x 3/4 aluminum "L" bracket. You can get this in a 5 foot length from Home Depot. You'll also need a 1.5 inch bolt and lock nut. I can make these if you cannot make it yourself.
I'm still working on my write up for the vortech supercharger tear down, I'll do a detailed one for this once I'm done with that.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 03-22-2014, 08:23 PM   #2
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
I was thinking about doing this as well when I had them off for the SC install. Good idea for the bracket.
I wonder about the insulation though?
Lawnik is offline   Reply With Quote
Old 03-22-2014, 08:28 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
They are noise insulator.
Rayme is offline   Reply With Quote
Old 03-22-2014, 08:32 PM   #4
Wonderbar
Driveway labs.
Wonderbar's Avatar
The drivers side bracket is much closer to the rail, my guess is shock absorber. Doesn't make sense to insulate the side that doesn't have a computer attached to it, but not insulate the side that does.
Old 03-22-2014, 08:36 PM   #5
Wonderbar
Driveway labs.
Wonderbar's Avatar
That makes sense.
Old 03-24-2014, 05:04 PM   #6
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Wouldn't steel covers for the fuel rail system be important in a front end collision?
Jyn is offline   Reply With Quote
Old 03-24-2014, 06:32 PM   #7
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
That's the Flux Capacitor, dude. Put it back.
XanRules is offline   Reply With Quote
Old 03-24-2014, 06:37 PM   #8
Wonderbar
Driveway labs.
Wonderbar's Avatar
Not really.
Old 03-25-2014, 03:23 PM   #9
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Wonderbar View Post
I'm looking at this picture and imagining how long it would be before my wife stopped ripping into me for putting crap from my engine on her food scale.
What is the container in the upper left with the shapely legs and "A good gift for bad people" logo?
Old 03-25-2014, 03:30 PM   #10
Wonderbar
Driveway labs.
Wonderbar's Avatar
Hahaha that's my special edition Sailor Jerry's bottle of rum.
The food scale is easy, I'll look for the pictures of when I had the dishwasher full of parts when I was stripping the paint off of them. Hahaha
Old 03-25-2014, 03:30 PM   #11
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Not really.
Subaru implemented this setup in their cars a while back. First cars I remember seeing them in are the WRX, so 2002. They are referred to as the Green Brackets of Death, simply because those versions on the EJ205 were a bish to remove.
They are there for side impacts, and protect the otherwise exposed injectors from a hard bonk. In the worst case and without those brackets, you'd spill raw fuel on a hot motor/exhaust.
With that being said, they were an item quickly removed and never reinstalled just because of the headache they provided with removal/reinstallation.
Travisty75 is offline   Reply With Quote
Old 03-25-2014, 03:58 PM   #12
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
just make sure that ecu is properly grounded out and you dont just zip tie it in there somewhere. that ecu is grounded through that bracket. i zip tied my ecu unit to the rear brace to start the car after i put new port injectors in so i could check for leaks. yeah, that turned into a 2 day nightmare trying to figure out why the car would not run. bolted that bracket back in and bolted the ecu to it and problem solved.
Old 03-28-2014, 01:45 AM   #13
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Travisty75 View Post
...They are there for side impacts, and protect the otherwise exposed injectors from a hard bonk. In the worst case and without those brackets, you'd spill raw fuel on a hot motor/exhaust....
Those are the direct injector rails aren't they? Fuel spraying into the engine bay at 5000psi after a side collision would be an interesting experience.
Great info here, thank you.
Gents...
Have you noticed much, if any, extra injector noise after removing these?
1974 TA22 Celica
2013 86 GT
Old 03-28-2014, 02:08 AM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Nice, quick and easy weekend project!
is this an easy fix? ijuliusx Northern California 6 03-01-2014 11:05 AM
Anyway easy way to fix this? FRSure Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 01-06-2014 09:54 PM
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Advan TC2 17x8.5 +45 - Gold - 16.5lbs each No Limit Motorsport Wheels and Tires 24 03-20-2013 11:07 AM
How easy to work on boxer engine? civdaddy Scion FR-S / Toyota 86 GT86 General Forum 5 02-03-2013 07:22 PM
