Old 09-30-2018, 04:42 PM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
OFT V4.0x Flash Dyno Results
I thought I'd post this here incase anyone was curious on the results.
2013 BRZ
6 Speed
56,000 Miles
Performance Mods:
Tomei UEL Headers
Motiv Overpipe
Motiv Front Pipe with High Flow Catalytic Converter
Perrin 2.5" Resonated Catback
Open Flash Tuner (OFT) with stage 2+ 4.0x Tune
93 Octane Gas
Supertek Intake Inlet w/ K&N Filter
184hp/148trq to the wheels
-B
Graph 1 = Stage 2+ v4.0x with mods
Graph 2 = Stock Tune with Perrin Catback/Intake vs. Stage 2+ v4.0x with mods
[ame]https://www.youtube.com/watch?v=ddpEoUDuFkk[/ame]
HeresMyMind is offline   Reply With Quote
Old 09-30-2018, 04:49 PM   #2
Somerandom18
Drives: 2017 manual BRZ
184 on a heartbreaker very nice. Thanks for the post! Have any e85 to play with where you're located?
Sent from my Pixel 2 XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 09-30-2018, 05:18 PM   #3
HeresMyMind
Only like 1-2 spots in CT sells t and it’s not close to me lol.
-B
Old 09-30-2018, 10:33 PM   #4
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
@HeresMyMind is that a standard/non-modified OFT stage 2+ 4.03 off-the-shelf ROM?
Torque Dip is completely gone, replaced by small bump at around 4500 RPM!
Spec C Wannabe is offline   Reply With Quote
Old 10-01-2018, 12:54 AM   #5
jflogerzi
jflogerzi's Avatar
Very nice TQ curve. I plan to get my car done on 91 and e85. Modified tunes done by a member based on the v4 oft base tunes.
2013 Series 10 FRS #553
Old 10-01-2018, 06:14 AM   #6
HeresMyMind
Completely unmodified.
The run was also after the IAM got up to 1.0 after a few light pulls.
My mods just Happened to be the perfect combo for this flash.
I may be able to squeeze a tint bit more power by leaning it out to 12.5 afr average but the 11.9-12 is more on the safer end. Especially for a generic map.
-B
Old 10-01-2018, 06:23 AM   #7
tomm.brz
Drives: brz 2017 hksv2
or you could try rising a bit the timing without leaning the afr, timings on v4 are not sooo extreme
Old 10-01-2018, 06:26 AM   #8
HeresMyMind
I’m very happy with these results. Maybe I’ll get an ECUtek dyno tune by my shop (EFI Logics) but no rush. Maybe winter when they are slow or something.
-B
Old 10-01-2018, 06:46 AM   #9
tomm.brz
you could do that in few minutes with romraider just few logs to see if it knocks, if all goes well you could have a bit more power and better fuel economy
Old 10-01-2018, 09:47 AM   #10
86TOYO2k17
Drives: 2017 toyota 86
-B
not bad, would be interested to see a stock comparison.
Also +1 for doing a ecutek comparison.
i have a custom oft tune, but have been thinking about getting a custom dyno ecutek tune.
Old 10-01-2018, 09:54 AM   #11
HeresMyMind
2013 Baseline (perrin catback / intake with no tune)
Old 10-01-2018, 11:30 AM   #12
bfrank1972
Drives: 2013 FR-S Argento
Wow very nice - just a quick and dirty comparison, torque gains around 20% in the 3000's. Then around 10% average between 4000 and 6000. And then great gains on the top end, peak gain of about 24% near redline. All with a 'canned' tune.
But wait, this can't be right. I just read on here that the only good header out there was the $1400 ACE? Everything else was crap with torque dips.
bfrank1972 is offline   Reply With Quote
Old 10-01-2018, 11:50 AM   #13
HeresMyMind
I believe ACE is the best header for all around results and being EL.
Most EL headers still have the torque issue. The only one I've seen that has a flat trq value are HKS EL's. Although I dont think they have the best overall gains. Check out these results.
-B
Old 10-01-2018, 11:51 AM   #14
HeresMyMind
All UEL comparisons
-B
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
Baseline Dyno Results JJJ Engine, Exhaust, Transmission 2 06-23-2015 06:49 PM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
