#29 |
not playing cards
[ame="https://www.youtube.com/watch?v=-xLUEMj6cwA"]Life of Brian - Blessed are the cheesemakers - YouTube[/ame]
Although if one were so inclined, one could also shove something down in between the cable and the inside of the shift lever.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (10-09-2017) |
#30 | |
Maybe I do too ....... I'll ask my wife (who is younger) to listen for it ....... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ehokana (10-10-2017) |
#31 |
| The Following User Says Thank You to humfrz For This Useful Post: | strat61caster (10-09-2017) |
#32 |
Drives: 22 BRZ
2017 here starting to hear the same thing. my 2013 was horrible anything above 4k would rattle.
#33 |
Drives: 2017 86 Coupe
I am on my second 2017, first 86 had 5400 miles. My new 860 is at 800 miles, so I have not gone past 4500 RPM's yet. I did notice on my first 86, that it did have a buz through the gear knob. It stoped when I installed my TRD knob.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter |
#34 |
Drives: 2013 Scion FRS
If your shifter isn't rattling, you just haven't driven the car long enough.
Sent from my HTC6535LVW using Tapatalk |
#35 | |
![]() No, that means that you just know how to shift a MT properly and not treating the stick like it's reaching down into a box of hot, greasy gears and knocking them around till one is kicked into place ........ ![]() ....... that's just for good measure!![]() humfrz |
#36 | |
| The Following User Says Thank You to MurderousPandas For This Useful Post: | Beachin86 (10-11-2017) |
#37 |
Wheels for Brains
I've got a rattle/ringing, but it's due to the TRD USA Short Shifter assembly bolt. Still working out the kinks in it; I go under to tighten it up every couple of weeks. Might just need to lather the thing in Blue Loctite
#38 | |
Just don't get over the torque dip and it doesn't rattle. Besides, some of you folks are going the wrong way with shifters ...... make them longer ..... NOT shorter. We didn't have that problem back in the day ..... ![]() humfrz |
#39 | |
![]() humfrz |
#40 | |
not playing cards
They all rattle. Yours likely needs a good Italian tune up.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (10-12-2017) |
#41 | |
![]() As far as the torque dip ....... if I never put my car on a dyno ...... I'll never know if it has a torque dip ....... therefore, my car doesn't have a torque dip. Ya, I've read about those Italian tune up with these cars ....... they cause spun bearings, burnt up coil packs, blown DI seals, leaking timing chain covers, messed up clutches and crunchy shifting transmissions. No thanks! So there! humfrz |
#42 |
not playing cards
| Vibrating shifter fix! | Superhatch | Issues | Warranty | Recalls / TSB | 51 | 06-05-2016 11:56 PM |
| Torque dip sound: rattling / vibrating | mike_ekim1024 | Software Tuning | 6 | 11-06-2013 03:17 PM |
| Exhaust is vibrating a bit.. | pgeist | Engine, Exhaust, Transmission | 3 | 07-09-2013 03:00 AM |
| Buzzing/vibrating speaker fix | CBR600RR | DIY (Do-It-Yourself) Guides | 3 | 05-21-2013 01:11 PM |
| Gear Stick HELP | FaNtaSy | Engine, Exhaust, Transmission | 12 | 03-18-2013 12:03 AM |
