Old 10-09-2017, 01:09 AM   #29
How does that solve anything?
[ame="https://www.youtube.com/watch?v=-xLUEMj6cwA"]Life of Brian - Blessed are the cheesemakers - YouTube[/ame]
Although if one were so inclined, one could also shove something down in between the cable and the inside of the shift lever.
strat61caster (10-09-2017)
Old 10-09-2017, 03:25 AM   #30
Originally Posted by etherdude View Post
I have a heavy white "cue ball" knob on the end of my shifter. Love the way it feels. The shifter buzzes above 5000 rpm in 2nd and 3rd, but no prob for me. I have 40,000 miles on my 2015 and it adds "charm". Plus at 66 yrs old, my hearing isn't too good, so I can hear that a lo0t better than the cheesy little shift warning bell I programmed for 6800 rpm.
Doug
You have a shift warning bell ...... ??
Maybe I do too ....... I'll ask my wife (who is younger) to listen for it .......
Ehokana (10-10-2017)
Old 10-09-2017, 03:31 AM   #31
I reckon it's time for me to sign off for the night ....... you folks aren't making any sense to me ........
ZZZZZZ
Old 10-10-2017, 10:40 PM   #32
ZX88
ZX88's Avatar
Drives: 22 BRZ
2017 here starting to hear the same thing. my 2013 was horrible anything above 4k would rattle.
2013 TRD FRS
2017 TRD Toyota 86
2022 BRZ
ZX88 is offline   Reply With Quote
Old 10-11-2017, 09:24 AM   #33
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
I am on my second 2017, first 86 had 5400 miles. My new 860 is at 800 miles, so I have not gone past 4500 RPM's yet. I did notice on my first 86, that it did have a buz through the gear knob. It stoped when I installed my TRD knob.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 10-11-2017, 12:22 PM   #34
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
If your shifter isn't rattling, you just haven't driven the car long enough.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 10-11-2017, 12:45 PM   #35
No, that means that you just know how to shift a MT properly and not treating the stick like it's reaching down into a box of hot, greasy gears and knocking them around till one is kicked into place ........
....... that's just for good measure!
Old 10-11-2017, 05:37 PM   #36
MurderousPandas
I have yet to see/hear a twin not rattle. Stock they rattle, throw on some bushings and it multiplies. Add an air freshener around it like i did and it turns into a maraca.
The Following User Says Thank You to MurderousPandas For This Useful Post:
Beachin86 (10-11-2017)
Old 10-11-2017, 06:26 PM   #37
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I've got a rattle/ringing, but it's due to the TRD USA Short Shifter assembly bolt. Still working out the kinks in it; I go under to tighten it up every couple of weeks. Might just need to lather the thing in Blue Loctite
EndlessAzure is offline   Reply With Quote
Old 10-11-2017, 08:51 PM   #38
Well, my stock 2013 FR-S shifter does NOT rattle.
Just don't get over the torque dip and it doesn't rattle.
Besides, some of you folks are going the wrong way with shifters ...... make them longer ..... NOT shorter. We didn't have that problem back in the day .....
Old 10-11-2017, 08:59 PM   #39
My friend Bubba, could fix that right up fer ya .......
Old 10-11-2017, 10:42 PM   #40
Don't get over the torque dip? Come on. You can't be serious.
They all rattle. Yours likely needs a good Italian tune up.
humfrz (10-11-2017)
Old 10-11-2017, 11:43 PM   #41
My shifter does NOT rattle ...... if it does, I can't hear it ....... therefore, it's like the tree falling in the forest, ...... it makes no sound ......... cause I can't hear it ..........
As far as the torque dip ....... if I never put my car on a dyno ...... I'll never know if it has a torque dip ....... therefore, my car doesn't have a torque dip.
Ya, I've read about those Italian tune up with these cars ....... they cause spun bearings, burnt up coil packs, blown DI seals, leaking timing chain covers, messed up clutches and crunchy shifting transmissions. No thanks!
So there!
Old 10-11-2017, 11:54 PM   #42
So there!
humfrz (10-12-2017)
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Torque dip sound: rattling / vibrating mike_ekim1024 Software Tuning 6 11-06-2013 02:17 PM
Exhaust is vibrating a bit.. pgeist Engine, Exhaust, Transmission 3 07-09-2013 02:00 AM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
Gear Stick HELP FaNtaSy Engine, Exhaust, Transmission 12 03-17-2013 11:03 PM
