Old 12-01-2016, 11:02 AM   #29
Originally Posted by wbradley View Post
Would have had the same issue on a manual if the switch behind the clutch pedal failed. duh
Brake interlock was my suspicion.
Ya, if I hadn't had it firmly in my head that he had a MT for some weird reason (he never once says it) I may have clued in.
Old 12-03-2016, 11:05 PM   #30
WWFT86
Drives: 2017 BRZ Limited
Brake light switch -that's it - dealer claimed that was the cause for ABS and Slip indicator as well as car not turning over
The only thing I know of that is there is the brake light switch and that should not throw a brake system warning and certainly would not stop the car from starting. Unless there is another sensor I am not aware of. Anybody? Something doesn't add up.
Edit:
Thought so. No sensors.
WWFT86 is offline   Reply With Quote
Old 12-04-2016, 12:04 AM   #31
WWFT86
This is right on the money. Wish I found this earlier. Yes I have an AT but always used the manual mode except when I have food or drink in one hand...
Thanks for pointing out this bulletin.
Originally Posted by Imrac View Post
He probably has an Automatic, Brake pedal must be pressed for the engine to start.
Also take a look at this thread:
http://www.ft86club.com/forums/showthread.php?t=67825
Kinda smart... Look at the master cylinder pressure, see the increase in pressure, realize the brakes switch is not closed (Or open, or what ever the position should be).
Old 12-05-2016, 01:47 AM   #32
89_Manny
89_Manny's Avatar
Drives: Firestorm FR-S '13
I will try this as well!
After I upgraded all my brakes the lights go off. Even more in traffic or when I merge
89_Manny is offline   Reply With Quote
Old 12-05-2016, 08:22 PM   #33
WWFT86
Just the occasional bagel or coffee in hand For pgone I'd pull over or just wait.
Old 04-08-2017, 04:26 PM   #34
WWFT86
For the 2nd time in 4 months, this problem came back on my 2017 BRZ. Dealer said the brake light switch simply broke for unknown reason. I also hadn't touched that part of the cabin either (eg. Did not change mat, etc)
When I expressed concerns if this could happen while driving, the service person simply shrugs...
Now I feel very confident about my car... and the weather is just getting nice.. sigh..
Old 04-08-2017, 04:27 PM   #35
WWFT86
Fault code = C1249
Help needed. Indicators and headlight not turning on Suffa Electronics | Audio | NAV | Infotainment 0 10-05-2014 05:38 AM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 01:14 PM
Replace front DRL/indicators on GT/FRS 2SeeKU Cosmetic Modification (Interior/Exterior/Lighting) 11 11-29-2013 10:38 PM
Single tap indicators sav AFRICA 6 05-28-2013 02:24 PM
Side Mirror Indicators DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 03-24-2013 01:37 AM
