Old 10-05-2014, 04:38 AM   #1
Suffa
Drives: Black GTS
Exclamation Help needed. Indicators and headlight not turning on
Working on a friends car doing some wiring and a problem has started. Its possible the 12V constant from the flasher relay has shorted when it was spliced into.
The problems are all the lights seem to be stuck in park mode. License, rear position and dash illumination is all on.
Nothing on the indicator stalk is working. So indicators, headlights, high beams & rear fog wont turn on. It seems also the gear select (automatic) wont change and the gear override needs to be used.
Any ideas what has happened? It could be a fuse but i dont know which one it would be. Appreciate the help, need fixed asap.
Suffa is offline   Reply With Quote
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Replace front DRL/indicators on GT/FRS 2SeeKU Cosmetic Modification (Interior/Exterior/Lighting) 11 11-29-2013 09:38 PM
Single tap indicators sav AFRICA 6 05-28-2013 01:24 PM
Side Mirror Indicators DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 03-24-2013 12:37 AM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
