Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-11-2014, 10:14 PM | #1 |
Brake Light Switch Fault - TSB Fix
I have been dealing with a random issue with my TCS/ABS MIL illuminating after car is hot and sitting at a stop with the brake pedal depressed.
The DTC Code Is: C1249 There is a TSB for this issue from Subaru which applies to multiple cars. 06-44-12 So Subaru warns if you frequently pump the brake pedal you can have a malfunction and says don't pump the brakes. Or in the case if you constantly bleed your brakes testing pedal feel its possible that the brake switch can get out of adjustment. In my case the switch was not activating the brake light when I pressed the brake lightly, so the ECU looks at master cylinder pressure and says why is there pressure and no brake light and throws a code. 1. Unlock the switch module by turning it counter clockwise. 2. Push the switch toward the pedal if your brake light is on without touching the pedal and the lock and test. 3. Pull the switch away from the pedal if the brake light is not illuminated immediately when depressing the pedal and lock then test.
The Following 9 Users Say Thank You to Dezoris For This Useful Post: | 86ft.lb (09-30-2017), brandonblt2 (07-05-2021), infinity21 (03-25-2019), MJones_RB (10-18-2017), Slade (05-19-2020), Sportsguy83 (08-09-2017), strat61caster (06-11-2014), Trog (06-27-2014), WWFT86 (04-08-2017) |
09-30-2017, 03:53 PM | #2 |
Drives: orange fr-s MT
Just finished the adjustment. The instruction is spot-on. Thanks Dezoris.
The Following User Says Thank You to 86ft.lb For This Useful Post: | jacjac3 (01-22-2020) |
01-21-2018, 02:39 AM | #3 |
Time Traveller
I just recently had to do this. Got ABS and Stability control lights on the dash and brake lights would not come on. Didn't want to go to the dealer so I replaced it myself.
Part number for Scion/Toyota is SU003-02490 SWITCH STOP LP LED for my 2013 FR-S. 1. Bought a new switch online for ~$20 and replaced the old one (just in case) 2. Forgot to adjust the switch and the lights came back on (of course) 3. Adjusted the switch by: rotating it to unlock it 4. Then pulling it out to let the brake pedal come all the way to the top if its travel. 5. Then I pushed the switch in gently until the button was full depressed. 6. Finally, I rotated the switch clockwise to lock it in. Dashboard lights turned off immediately and brake lights work again. All good. Last edited by DAEMANO; 09-01-2018 at 09:21 PM. |
The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | JEFFSTYLE (05-22-2022), TheBRZsKnees (12-17-2018) |
Similar Threads | ||||
So where will the fog light switch go... | Asphalt | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-08-2019 07:09 PM |
Where is your Fog light switch? | SillySaxon | BRZ First-Gen (2012+) -- General Topics | 10 | 07-11-2014 10:51 AM |
Brake Switch Fault | TSB FIX | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-11-2014 10:11 PM |
How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED | tiz22 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-04-2014 01:16 AM |
Brake switch adjustment ? | photomike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 02-20-2013 01:49 AM |
