Old 02-16-2016, 12:57 PM   #29
Ultramaroon
not playing cards
Ultramaroon's Avatar
Holding full throttle before and while cranking the engine triggers flood-clearing mode. Fuel is cut. We can listen for obvious valve and compression issues by cranking the engine this way. If there is a cylinder leaking, we'll hear an uneven lope as the starter motor fails to labor over that cylinder's compression stroke. If you want, maybe upload another clip.
I hear something leaking in your first vid but I think it's just a vacuum line disconnected.
Compression test would be a bitch because it involves a pressure gauge in place of a spark plug.
Old 02-17-2016, 12:39 AM   #30
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
I will be purchasing a MAF sensor this weekend from the local dealer, once I do that I will record a video in flood clearing mode. I will also have the MAF installed and hopefully both these diagnoses shall shed some light on the issues I'm facing.
driftking96 is offline   Reply With Quote
Old 02-19-2016, 07:43 PM   #31
driftking96
Hey guys,
Got some good news and more bad news.
The good: I used my existing MAF sensor as I didnt want to pay over $200 for a new one. Now i talked to the local dealership and they said my car should be able to start without a MAF and it will be fine just not optimal. I was also able to remove the MAF sensor attached to the car, remove the broken pieces of plastic it was attached to and today I plugged it back in the car and left inside the pipe instead leaving it hanging outside. I started the car in flood clearing mode first and it didnt start, so then i tried starting it normally and guess what? It did.
THE BAD NEWS: The car would stall immediately if i didn't continuously push the throttle to keep the RPMs high. As soon as I let go of the throttle it would immediately drop without idling and stall/die. I also have more problems now and I feel like I need to start a new thread (and link to it here) regarding new issues.
NEW THREAD FOR NEW ISSUES: http://www.ft86club.com/forums/showthread.php?p=2554492
Old 02-19-2016, 10:49 PM   #32
Ultramaroon
not playing cards
Originally Posted by driftking96 View Post
Hey guys,
The engine wasn't supposed to actually start. That's the whole reason for the flood-clearing mode. Without coolant, the critical parts of the engine will overheat in very short order: a minute or so.
cel, engine, stalls
Car will not starts at all Tomahawk Issues | Warranty | Recalls / TSB 74 02-06-2016 07:32 PM
Do e85 cold starts damage engine? jaorocks1 Engine, Exhaust, Transmission 20 12-02-2015 05:12 AM
Strange beep sound from engine on starts fanaticalz Issues | Warranty | Recalls / TSB 5 05-19-2015 01:10 AM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
