#29 |
Holding full throttle before and while cranking the engine triggers flood-clearing mode. Fuel is cut. We can listen for obvious valve and compression issues by cranking the engine this way. If there is a cylinder leaking, we'll hear an uneven lope as the starter motor fails to labor over that cylinder's compression stroke. If you want, maybe upload another clip.
I hear something leaking in your first vid but I think it's just a vacuum line disconnected. Compression test would be a bitch because it involves a pressure gauge in place of a spark plug.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | driftking96 (02-17-2016) |
#30 | |
Drives: 2014 Scion FR-S, 1998 Honda Accord
#31 |
Hey guys,
Got some good news and more bad news. The good: I used my existing MAF sensor as I didnt want to pay over $200 for a new one. Now i talked to the local dealership and they said my car should be able to start without a MAF and it will be fine just not optimal. I was also able to remove the MAF sensor attached to the car, remove the broken pieces of plastic it was attached to and today I plugged it back in the car and left inside the pipe instead leaving it hanging outside. I started the car in flood clearing mode first and it didnt start, so then i tried starting it normally and guess what? It did. THE BAD NEWS: The car would stall immediately if i didn't continuously push the throttle to keep the RPMs high. As soon as I let go of the throttle it would immediately drop without idling and stall/die. I also have more problems now and I feel like I need to start a new thread (and link to it here) regarding new issues. NEW THREAD FOR NEW ISSUES: http://www.ft86club.com/forums/showthread.php?p=2554492 Last edited by driftking96; 02-19-2016 at 08:21 PM. |
#32 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | driftking96 (02-20-2016) |
| Tags |
| cel, engine, stalls |
| Car will not starts at all | Tomahawk | Issues | Warranty | Recalls / TSB | 74 | 02-06-2016 07:32 PM |
| Do e85 cold starts damage engine? | jaorocks1 | Engine, Exhaust, Transmission | 20 | 12-02-2015 05:12 AM |
| Strange beep sound from engine on starts | fanaticalz | Issues | Warranty | Recalls / TSB | 5 | 05-19-2015 01:10 AM |
| jerky starts | goshem | BRZ First-Gen (2012+) — General Topics | 14 | 01-19-2014 11:21 PM |
| Engine doesn't start right away | Cajun | Issues | Warranty | Recalls / TSB | 1 | 02-04-2013 02:09 PM |
