Old 02-15-2016, 01:03 AM   #1
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
Engine starts but doesn't run
Hey guys, I have two CEL codes which I posted about on a earlier thread
http://www.ft86club.com/forums/showthread.php?t=101578
But on a separate note because I don't think my two CEL codes are preventing me from starting and running my engine (Please correct me if I'm wrong). Battery is at 13.5 volts. all lighting works, alarm works, car is stock with no mods. Just put in 20L of premium Shell VPower Nitro just to make sure it wasn't the gas decomposing and causing issues. When I put my key and turn it once, my accessories are all powered on and I hear a whirring sound (Common apparently due to throttle opening, I may be wrong). Then when I turn my key again, all my lights come up on the cluster. Try starting my car and it cranks, so I think the starter works and then it ceases and fails to run the actual engine and goes out with a giant puff sound which I think is air being sucked from the intake area (which I took off cos it was broken). Any ideas fellow twin owners/enthusiasts? Thanks in advance.
EDIT: Got in to a front end crash.
driftking96 is offline   Reply With Quote
Old 02-15-2016, 01:19 AM   #2
_gt86_user
Inactive
Drives: .
buy a new whatever was broken on your intake and try it again.
_gt86_user is offline   Reply With Quote
Old 02-15-2016, 01:24 AM   #3
driftking96
It was literally the plastic stock intake piece. I highly doubt that is the reason the engine can crank but doesn't run.
Sent from my ONE A2005 using Tapatalk
Old 02-15-2016, 01:27 AM   #4
_gt86_user
Inactive
Drives: .
What stock intake piece? And did you just leave it open or plug it somehow? Anyways if you don't think that's what it is, then all good. You're the one who asked.
Your post reads that you removed the "air intake area" which is confusing since it sounds like your trying to start your car with no intake. You said your car was stock so if you removed the OEM intake and have nothing there that might be the problem lol.
Old 02-15-2016, 01:35 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
pic of the stock intake piece that's broken.
Old 02-15-2016, 01:45 AM   #6
driftking96
I'm bout to drive. I will fully reply and post pics as soon as I can. FYI I got into a front end crash so yea. Tryna fix and figure some things out myself.
Old 02-15-2016, 04:54 AM   #7
steve99
If the car wont start after crash then its likely related to crash damage.
both codes relate to throttle actuator issues.
pull off the intake and make sure nothig is stuck in throttle plate
turn ignition on ( dont try to start) get a friend press throttle and see if throttle plate moves full range freely.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Chrisgalactic (02-16-2016), driftking96 (02-15-2016)
Old 02-15-2016, 05:39 AM   #8
slowest86
Drives: slow frs
Could have sucked in broken pieces of the air box.
slowest86 is offline   Reply With Quote
The Following User Says Thank You to slowest86 For This Useful Post:
Old 02-15-2016, 12:39 PM   #9
_gt86_user
Inactive
Drives: .
Wow, could have just said you were in a front end collision in your OP.
Old 02-15-2016, 12:52 PM   #10
kev60625
Drives: 2013 WRB Subaru BRZ
Leaves that out as if it doesn't matter
kev60625 is offline   Reply With Quote
Old 02-15-2016, 01:08 PM   #11
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
*Looks at username* ...We want to hear the story of this front-end accident. With pics.
Then we will help you fix it.
The pictures will help in that endeavor.
Need to see the throttle body and intake manifold before I can help with the actuator and min stop code.
If the throttle body motor isn't working properly, the car will not start or idle. It's a drive-by-wire throttle.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Dream20b (02-15-2016)
Old 02-15-2016, 03:38 PM   #12
Panamaniac
I am rebuilding a salvage title FRS, and had this same issue last week.
My issue was grounding....
My injector driver module (EDU) stand was broken and it was just sitting next to the baterry, I added a ground cable to it and the car started with no problem.
Panamaniac is offline   Reply With Quote
The Following User Says Thank You to Panamaniac For This Useful Post:
Old 02-15-2016, 06:08 PM   #13
driftking96
Lol I didn't mention accident cos its like mentioning something bad. Not proud of it but w.e my fault for not educating you guys enough about the issue I have. Anyways I checked the throttle body when I had some time today and turns out I had a plastic piece stuck in it. I'm hoping it will clear the engine codes and then I will continue to remove and inspect the manifold just to be safe. I attempted to start the car before and I failed. I'm just hoping I didn't damage anything due to me not knowing the plastic piece was affecting the throttle body and perhaps even the manifold. When I get a chance to inspect it today I will.
Old 02-15-2016, 06:10 PM   #14
driftking96
I will also take a look at the EDU just to be safe and keep you posted. Thanks for the valuable info brother.
cel, engine, stalls
Car will not starts at all Tomahawk Issues | Warranty | Recalls / TSB 74 02-06-2016 07:32 PM
Do e85 cold starts damage engine? jaorocks1 Engine, Exhaust, Transmission 20 12-02-2015 05:12 AM
Strange beep sound from engine on starts fanaticalz Issues | Warranty | Recalls / TSB 5 05-19-2015 01:10 AM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
