Old 02-01-2016, 12:06 AM   #1
Tomahawk
Drives: 13 FRS
Car will not starts at all
So for whatever reason my 13 frs won't start. I have two key fobs and both have new batteries and I'm able to turn the car into aux mode but won't turn over at all. The light is on in the dash showing the alarm is on even though the alarm is off (pressing the unlock on the fob) checked every fuse and they're all good to go. Lights, dome lights and all dash lights turn on just fine and battery is new too. I was on a deployment and didn't drive the car everyday so my dad would drive it once a week and car ran just fine but now it won't even do a damn thing. It's FI and Ive had no problems with the car whatsoever. Very frustrating and want to get to the bottom of this. Oh and the fob does unlock and lock the car.
Tomahawk is offline   Reply With Quote
Old 02-01-2016, 12:11 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Do you know what the voltage is on the car's battery is? When's the last time your father started it?
Old 02-01-2016, 12:15 AM   #3
Tomahawk
Drives: 13 FRS
He started it last week and took the battery to autozone and it was fine
Old 02-01-2016, 12:21 AM   #4
steve99
clutch switch or park/neural switch may be faulty
Old 02-01-2016, 12:30 AM   #5
Tomahawk
Drives: 13 FRS
Is that a costly fix? I know the clutch switch is under the dash, was looking at it earlier but don't know where the park neutral switch is at
Old 02-01-2016, 12:32 AM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
FI as in fuel injection or forced induction?
Do you hear a metallic click from the starter when turning the key? The stock pos Panasonic is krap. With just a .03 mine wouldn't start. Everything else worked 100% fine.
Packofcrows is offline   Reply With Quote
Old 02-01-2016, 12:35 AM   #7
humfrz
I don't think your car has both.
Is it a MT or AT .. ??
humfrz
Old 02-01-2016, 12:36 AM   #8
Tomahawk
Drives: 13 FRS
Car won't even click over when I turn the key but the starter and alternator are new so o I know that isn't the issue is and it forced induction. Has a FBM stage 1
Old 02-01-2016, 12:37 AM   #9
Tomahawk
Drives: 13 FRS
humfrz
Damn I went dumb on that one haha I have a headache since I've been trying to figure out what's going on but it's MT
Old 02-01-2016, 12:39 AM   #10
Packofcrows
Get meter and check voltage. Make sure power is good, then fuses.
Old 02-01-2016, 12:44 AM   #11
Tomahawk
Drives: 13 FRS
Already checked battery and it's good to go and all fuses are good as well.
Old 02-01-2016, 12:44 AM   #12
humfrz
There ya go, ol @Packofcrows is on the case .....
http://www.aa1car.com/library/battery_runs_down.htm
Also, make sure the battery connections are clean and tight.
humfrz
Old 02-01-2016, 12:47 AM   #13
humfrz
OK, hmmmmm ........what voltage is the battery putting out .. ??
humfrz
Old 02-01-2016, 12:50 AM   #14
Tomahawk
Drives: 13 FRS
humfrz
Did all do this already and everything is good. It's just a weird situation I'm in because everything checks out good yet the car just doesn't want to turn on.
Car only starts when primary 02 is unplugged j0hnnybk01 Issues | Warranty | Recalls / TSB 22 08-28-2017 11:13 AM
Random tip - cold starts Dammod AFRICA 34 09-22-2015 01:38 AM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
Jerky / shaky starts Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2013 01:27 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
