#365 |
Drives: 2013 Black FR-S
Not trying to cause an arguement but the turbo will have a pretty significantly higher output than the superchargers.
#366 |
Drives: 2013 BRZ Limited
#367 |
#369 |
I spy double-sided cog belt or are my eyes playing tricks on me? I'm curious, do the two cog gears shown have different pitch sizes?
#370 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
From that routing yeah it needs to be double sided.
Nolan
#371 |
I will reserve my final judgement for when this kit has officially be released and installed on some cars, but I think this may end up being the FI kit for me once winter has ended.
#372 |
That Guy
Drives: 2013 asphalt FRS MT
#373 |
That Guy
Yup, that was my first thought. I'm REALLY curious why they didn't use two pulleys, mounted lower then the SC drive pulley, and a single sided belt. They could have maintained the same pulley coverage, and could have mounted the tensioner assembly at a 45 deg which would have made it easier to adjust while it's mounted to the car. This way, all pulleys have to be cut with a gear pattern, they have more pulleys, and a longer & more expensive belt. I'm wondering what was in the way. ???
#374 |
Modern superchargers aren't as inefficient as they used to be... I made 360WHP with 11.5PSI on E85 and a full stock exhaust with stock header, both cats... I am pretty close to most of the turbo guys in my pressure range. Sure the turbo guys may be slightly better, but a lot of turbo setups have 1 or 0 cats, full exhaust, high flow header, etc. Mid range power? sure, they make more psi at a lower RPM with the downside of a higher transient lag than I have. But saying that a ton of power is lost by using a supercharger isn't fully accurate. But lets not take this thread off topic in a debate about what is better.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread Last edited by nelsmar; 10-28-2013 at 06:06 PM. |
#375 | |
Drives: 2013 Hot Lava FR-S 6 MT
so long as the pulleys have a bevel of some sort on the inside edge it will collect the belt and spin accordingly provided there is proper tension in the belt system ... As for the pulley count and placement, I seem to remember a best practice of having a pulley between each cogged wheel in a machinist environment ... not sure if that applies to engine bays ... It's been years since I had that training ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#376 | |
That Guy
Two pulleys would still satisfy that best practice, would it not? My thought is that there would be two pulleys on either side of the compressor, but lower instead of above the compressor pulley. I'm not trying to argue here, I'm just trying to expand on my earlier post to ensure I wasn't misunderstood. I posted my idea expecting to be told it wouldn't work, I'm just not sure why it wouldn't work. |
#377 |
Oh I'm not trying to argue either Calum ... just was cleaning some cobwebs off of some distant training I had on pulley and gear systems in production line equipment. I'm all for being 100 percent wrong and learning by my foolishness. Science and understanding require it!
#378 | |
Drives: 13 BRZ
| [TX] DFW General Discussion | feedbag | Southwest | 1488 | 06-18-2022 07:25 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 03:28 PM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 05:57 PM |
| Rotrex kit - why no build? | MindtheGap | Engine, Exhaust, Transmission | 5 | 10-26-2012 07:01 PM |
