Old 01-25-2014, 12:10 PM   #323
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
If it changes so little that you can bolt-on and use, then it also means that it changes the parameters so little, that it effectively is equivalent to the stock header.
Remember, we have a MAF based car that works off of volumetric efficiency tables. Volumetric efficiency changes if flow significantly changes, which is what throws off the tune.
It's a love/hate relationship Mike.... Damn your knowledge and brain power! LOL!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 01-27-2014, 04:35 AM   #324
Superstar
Drives: Honda
How does Honda MAF work? Never seem to have this issue with slapping on an intake for a Honda...
Superstar is offline   Reply With Quote
Old 01-27-2014, 04:38 AM   #325
On what car? The S2000 uses MAP, not MAF. The K can use MAP, MAF, or a hybrid.
Also, that intake is probably not *really* doing anything
Old 01-27-2014, 09:14 AM   #326
sklimo
Today is going to be the longest day in the history of the world. I pick my baby up tomorrow!!!
The Following 5 Users Say Thank You to sklimo For This Useful Post:
*LongFella (01-27-2014), CSG Mike (01-27-2014), ramiram1984 (01-27-2014), shaunsweeney (01-27-2014), whitefrs (01-27-2014)
Old 01-27-2014, 10:09 AM   #327
mad_sb
Drives: 2013 Asphalt FR-S
I understand what you're saying. You want to ramp up the boost faster, and then restrict it, so that peak output isn't dramatically increased. What I'm saying is that there's only about 10% overhead left, so you can ramp up the boost 10% faster and still stay within the Rotrex's manufacturer's specifications.
Gotcha,
After digging some more it looks like using a restricter is not as clean a solution as i thought.. meaning the boost does not just level off and hold but rather will drop (in some cases like a rock) off sharply.. so you end up making peak power at lower rpm... not an appealing idea to me. I guess the "best" way to get more boost down low and maintain it at a safe level up top is with a gated setup.
Old 01-27-2014, 11:21 AM   #328
Originally Posted by mad_sb View Post
Gotcha,
Part of that is because the restrictor itself works as a velocity stack. A restrictor will actually *increase* power at a certain combination of flow and RPM, but ultimately limit power further up the powerband.
Check out the huge spike in power WRC cars have, and then the heavy nosedive as they go up the RPM range. The restrictor is to blame for that type of curve.
Old 01-27-2014, 12:06 PM   #329
ramiram1984
Drives: 2016 STi DGM
I'm excited to see other's numbers and feedback once installed.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
sklimo (01-27-2014)
Old 01-27-2014, 12:11 PM   #330
sklimo
I'll post my feedback and numbers tomorrow or Wednesday
The Following 4 Users Say Thank You to sklimo For This Useful Post:
CSG Mike (01-27-2014), OjiGeorge (01-27-2014), PrimeMotoring (01-29-2014), ramiram1984 (01-27-2014)
Old 01-27-2014, 12:51 PM   #331
sklimo
Teaser Pic
@Prime Motoring sent me a teaser pic!!!!! Figure I'd share
The Following 3 Users Say Thank You to sklimo For This Useful Post:
*LongFella (01-27-2014), Jackson Racing (02-14-2014), PrimeMotoring (01-29-2014)
Old 01-27-2014, 01:58 PM   #332
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Not sure if this is in the right topic. If I went with the Jackson CARB tune and then added a JDL header, will I get a check engine light? Would I have to buy two tune's? One for the stock header and one for the aftermarket header?
kurbkilla is offline   Reply With Quote
Old 01-27-2014, 02:06 PM   #333
*LongFella
*LongFella's Avatar
I asked a similar question. I was looking at the new ft86speedfactory catted UEL they are working on...
Simple answer - yes on a new tune. Not sure about the CEL though...
It would be best to get a tune that works and utilizes the header you add on... at least from what I gathered :-)
Old 01-27-2014, 02:20 PM   #334
CEL depends on the header.
If you're going to do breathing/exhaust mods, I'd recommend you do ALL the mods simultaneously, so that you don't have to constantly keep retuning.
Old 01-27-2014, 02:31 PM   #335
kurbkilla
kurbkilla's Avatar
I was looking at doing a header-back then then other mods. The very last being headers and supercharger. I would like to have the option of putting the stock header and front pipe on, and off. If I do that would I need two tunes.
Yes this is so I can smog the car anywhere I want.
Old 01-27-2014, 02:36 PM   #336
Ah, sounds like keeping the CARB tune for smog, and the other tune for "other times" will be perfect for you
kurbkilla (01-27-2014)
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
