Old 01-21-2014, 10:44 PM   #2801
xxscaxx
Drives: 2013 SWP BRZ
Those NGK plugs are the same I used on my STi when I stepped down to colder ones. But I wouldn't bother changing them unless instructed to.
xxscaxx is offline   Reply With Quote
Old 01-21-2014, 11:10 PM   #2802
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by CK_Bladesmith View Post
Pics of catch can location on your setup?
[IMG][/IMG]
[IMG][/IMG]
Can't really tell in the pic but I bolted it to an existing bracket on the engine. I think it held a wiring harness before the charger was added
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-21-2014, 11:19 PM   #2803
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
^ Awesome dude much appreciated.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-21-2014, 11:48 PM   #2804
CK_Bladesmith
Drives: Raven FR-S
Originally Posted by calispec View Post
[IMG][/IMG]
[IMG][/IMG]
Where did you get this specific catch can setup from?
Old 01-21-2014, 11:50 PM   #2805
calispec
calispec's Avatar
A couple pages back I posted a bunch of pics. Its by ADD. $80.
www.GT86Mounts.com
Old 01-21-2014, 11:51 PM   #2806
CK_Bladesmith
Drives: Raven FR-S
10-4. Much appreciated.
Old 01-22-2014, 11:17 AM   #2807
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by swift996 View Post
With so much emphasis on the circulating pump. I'm wondering if any of the electrical inclined might recommend a way to wire up a little LED light to the pump wiring? Sort of like when you check for a connection on a wire. I was thinking just running a tiny LED into the cabin so you can see the pump is working. It would only light up when the pump is on. Make sense?
I recommend a switch similar to these:
http://www.davis.com/Category/Kobold...Switches/52961
Install the flow switch inline anywhere in the system. The cold side is better than the hot side. Wire a 12vdc led from any normally on fuse (power) through to the paddle switch NC position (ground). This should trigger the led on anytime there isn't flow.
It'd be helpful to know the temperature range and chemical properties of the cooling fluid. Also the normally operating psi and flow rate would be helpful too. Get this info from innovate and call the switch company and ask the tech rep for something that might work. Pretty straight forward.
industrial is offline   Reply With Quote
Old 01-22-2014, 01:13 PM   #2808
xxscaxx
http://www.ft86club.com/forums/showp...postcount=2671
So I checked my coolant bottle together for my intercooler and its low again, right on the low mark. How many times did you guys have to fill it back up after first fill, if any?
Not sure if I need to check it while cool or not, but that was right when I got to work and shut the car off.
Old 01-22-2014, 03:00 PM   #2809
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Hey guys.....I am looking to get the Innovate SC perhaps this spring or summer depending on cash flow. My questions to you all who have this SC installed is:
1) Get the SC with or without the intercooler?
2) Are the "Tunes" that you get from Innovate for the Stage 1 and 2 Kits good tunes? I presume they are safe tunes that have been proven not to blow the engine and other parts to bits?
3) How much actual improvement does the Stage 2 Kit give you over Stage 1 with the Innovate tunes given with each setup (non-intercoolled vs. intercooled?)
I am not looking to push my engine to extreme WHP numbers that most likely require changing parts such as injectors, fuel pumps and transmission/differential parts. I am just looking to get the most from the engine with safe limitations.
Any advice and expertise is very welcome.
Thanks.....
Niko
PS - any mods that I will do engine-wise other than this SC would be getting an Invidia N1 or Injen exhaust (and possibly a cat-less front pipe). But that's it.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 01-22-2014, 03:14 PM   #2810
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Get the intercooler. IMO the non-intercooled kit shouldn't even be an option.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Calum (01-22-2014)
Old 01-22-2014, 04:02 PM   #2811
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
If you aren't willing to replace the stock injectors and possibly fuel pump stay away from FI. Fuel is the most important component of going FI and not the place to skimp IMHO.
shaunsweeney is offline   Reply With Quote
Old 01-22-2014, 04:16 PM   #2812
xjohnx
Grip>Slip
xjohnx's Avatar
Stock injectors are fine for over 300whp (I believe @DeliciousTuning is approaching 400 whp on stock injectors for one of his turbo tunes, and they actually run a lot smoother on my car than the DW700's did). The pump however will likely need to be upgraded.
Old 01-22-2014, 04:17 PM   #2813
swift996
swift996's Avatar
If I had waited I'd get the intercooled kit with CARB tune. I got impatient and figured it would take too long (for me it did).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-22-2014, 04:25 PM   #2814
shaunsweeney
Yeah the stock pump was never intended to be used in an FI application. Stock injectors usually have a better spray pattern as they were built with your combustion chamber in mind. The new AVO s3 injectors look promising though.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
