View Poll Results: Do You Use the Climate Control?
Yes 82 56.94%
Rarely 23 15.97%
No 19 13.19%
My car does not come with it 20 13.89%
Voters: 144. You may not vote on this poll
Old 11-05-2015, 03:30 AM   #15
Side
Side's Avatar
Drives: 2018 BRZ tS
Windows were frosted over this morning. Definitely took advantage of the heated seats, and pumped hot air for a minute before turning fan speed to low.
Side is offline   Reply With Quote
Old 11-05-2015, 03:50 AM   #16
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I use climate set to 22.5c in conjunction with seat warmers on high. Its rather relaxing when the seats hold you oh so perfectly snug.
Rarely use internal cycle, unless I'm behind a heavy polluter, either car or person (smoker).
If the outside temp is between 22c to 26c I'll turn off both and just roll the windows down otherwise, back to the same settings if either below or above that range.
Sydney's temps ranges from 10c all the way to 40c in a year.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 10-25-2017, 12:16 PM   #17
p1l0t
p1l0t's Avatar
Originally Posted by carma143 View Post
I am a guy who prefers to tweak the settings of everything I own. In cars I prefer to control the temp, air flow, the type of cooling, and whether the air comes from outside or inside.
For example in the mornings I'll use the cool air from outside instead of using the A/C.
So, do owners typically take advantage of the Climate Control?
I have the dual climate control setup which perfect because I like a cool 68 while my financ้e likes her side as hot as the depths of the... nevermind.
Leonardo (10-25-2017)
Old 10-25-2017, 12:23 PM   #18
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Only time its NOT on auto is when front screen defrost is on, otherwise its my default setting.
Press it and forget it.
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
Old 10-25-2017, 12:29 PM   #19
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
On days when the temperature is reasonable and climate control isn't necessary, it stays off.
In the summer, and in the winter, of course I use it. I set it to 72 in the summer, and 68 in the winter, and just leave it, for the most part. Auto climate control FTW! You don't realize how convenient it is until you have it.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 10-25-2017, 12:44 PM   #20
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Originally Posted by g e View Post
I love the alacantra seats and never thought I'd be a fan of the buns warmers but I'd miss them if I had to do without.
Same. It is actually the reason that I insisted on a Limited or Monogram because I had them in my previous car.
Yardjass is offline   Reply With Quote
Old 10-25-2017, 01:28 PM   #21
mazeroni
Drives: 2013 Scion FR-S Series 10
I'll hit the auto defrost button in the morning to defog the front and rear window, but I usually crack the windows as well. Then I turn it off once the windows are clear.
I dislike running the heat because it dries out my lips, eyes, and hands on already cold and dry days. I'd rather be cold than have chapped lips or a bloody nose.
It has to be over 90, or very humid for me to run the A/C. Smooth shifting is just too hard when the A/C is on. Then you have the engine stutters and revs bouncing up and down when at a stop. I'll suffer a little back sweat for a better drive.
I also keep my windows open even if it is raining - assuming we are going fast enough that the rain doesn't come in. But there again, I'd rather have my doors get wet than deal with what the AC does to the driving experience.
mazeroni is offline   Reply With Quote
Old 10-25-2017, 01:30 PM   #22
p1l0t
p1l0t's Avatar
I only turn off the A/C for race mode
Old 10-25-2017, 01:56 PM   #23
MRCA1ST
MRCA1ST's Avatar
Drives: 2013 WRB BRZ 6MT
I use mine on low just to keep air moving, I turn off the A/C when it comes on (unless it is super hot outside) and have my windows down as much as possible.
This topic brings up a question I had been meaning to ask, when the windshield defrost (or defrost/face vent) is selected you can't take it out of "auto" which I think means the A/C is engaged when needed...but it doesn't light up over the A/C button. So my understanding is that it is not possible to move air to the windshield without losing control of whether or not the A/C is on.
MRCA1ST is offline   Reply With Quote
Old 10-26-2017, 10:12 PM   #24
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by FT86.ca View Post
PS. The dual climate seems silly in a cabin that's so small imho.
I like the automatic controls also, and I've manipulated the settings every which way. I find that most of the responders above share the same techniques I have tried. Getting untreated air from outside boosted by just the fan was a bit of a challenge, but there's a way to do it.
Vic's dismissal of the dual automatic climate system is certainly a reasonable judgment and we've been through that discussion before. I just don't think the small cabin bears a major responsibility for disliking the automatic controls. My experience has been that when the cabin gets close to the set temperature, the system begins to mix warm and cool air so it can't overshoot the comfort zone. If it does, you've got your temp set too high or too low, or else something is amiss mechanically.
I still believe that the dual controls are useful, especially in the summer when the sun beats down on one lap and the other is in shade (notice it for a week or so; I think you'll see that it happens nearly all the time). "Set it and forget it" is maybe a little exaggeration, but I find it pretty nearly true on long trips.
Anyway, we may not need such a system in our cars, but I appreciate it as much as the same kind of control in my home . . .
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 10-27-2017, 01:43 AM   #25
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
I see this is an old thread, AND with a very poorly worded pole.
Someone mentioned in a post months ago that he has manual controls on his car. He also stated that the problem is having to do constant adjustments.
I also have manual controls. I also make constant adjustments. It's the only way, that I know of, to get what I want right now. I don't think there's a computer yet that knows what I want at any given moment.
The only problem I've had with all cars is that I am unable to get full defrost and sufficient air on my face at the same time. I know of no manufacturer's vehicle which allows this function.
ToySub1946 is offline   Reply With Quote
Old 10-27-2017, 07:51 PM   #26
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I do use climate control but in our mild winters here I prefer to drive with windows open and seat warmers on.
I am with you. Have heated seats in all my cars except my 2004 WRX, so I had to pay 300 to put one in. Once you go heat its tough without it.
Ernest72 is offline   Reply With Quote
Old 11-01-2017, 11:34 AM   #27
JMon85
JMon85's Avatar
Drives: 2019 WRX
Only during the winter
JMon85 is offline   Reply With Quote
Old 11-01-2017, 11:53 AM   #28
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
Climate control I find is useless at times (most times). Like when it's 45-50 deg out; sunny and the interior temp is warm say 70+ from sitting in the sun. well do you really want the AC on when it's 45 deg out when just a crack in the window and some fresh air is all you need to cool off the inside?
Plus I hate having the AC compressor run needlessly. The more you can have it off, the better fuel mpg etc. And let's face it, it robs power. I can feel a huge difference with the compressor cycling on.
I turn the AC on when I need it, and the heat when I need it. and adjust the temp to the current conditions.
Mostly I keep fan on low all the time for fresh air. and crank it up when I need more cooling or heat
bee-jay is offline   Reply With Quote
climate, temperature
Climate Control Conversion Codythatsme DIY (Do-It-Yourself) Guides 13 07-07-2015 04:58 PM
Climate Control Issue amishdude01 BRZ First-Gen (2012+) — General Topics 32 12-17-2014 05:15 PM
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 06:46 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 02:12 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 09:03 PM
