Old 07-04-2015, 07:17 AM   #1
Codythatsme
Drives: GT 86
Climate Control Conversion
Hello, a while ago there was someone on here selling custom harnesses to retrofit a premium model climate control panel to the base FRS. I was wondering if anyone else is making these? And if so what parts are required to buy? (Like the heat box, temp sensor, etc?)
Thanks.
Codythatsme is offline   Reply With Quote
Old 07-04-2015, 09:33 AM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
Take car to dealership. Trade in said car. Get car with climate control. Honestly, that's probably easier.
cdq85 is offline   Reply With Quote
Old 07-04-2015, 02:01 PM   #3
Chaetagnath
Drives: Whiteout FRS
Thanks.
I believe that guy who was making the harnesses got banned. But, before he was banned, I bought one of his harnesses. The harness itself is pretty complicated, but if you can figure out the wiring it would be possible I guess. I have all the parts but haven't actually done the install yet since it requires completely disassembling the dash, and as this is my daily driver I haven't had time to do it yet. If I ever do I will try to take pictures of the process.
In addition, you need the following parts:
72311CA061 the climate control panel
72100CA070 the automatic heater blower unit assembly
73730CA020 the temperature sensor
72313CA010 the hose assembly for the temperature sensor
All in all its at least 1000 bucks for those parts unless you can source them used.
The heater blower unit has to be switched out. I tried to retrofit my manual control heater blower unit with the parts which are different between the two, but it is just different enough to not be feasible. So, you must swap the whole unit out. Since its behind the dash, the dash must completely come out.
If you are interested, I included a picture of the guys harness. Your best bet would be to track him down somehow. I only contacted him through the forum, but a few people actually did this retrofit, and maybe they can PM you contact info for him.
Chaetagnath is offline   Reply With Quote
Old 07-04-2015, 02:23 PM   #4
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Totally agree. Don't be cheap and just buy a Limited to begin with. You're already blowing X dollars, why not spend an extra 1/10 (or less) of what you just spent to get everything and have no regrets later.
Old 07-04-2015, 02:32 PM   #5
stevesnj
stevesnj's Avatar
Is it too hard to turn the CC dials in this car is that why you want auto CC? I say in jest :P
My 2016 Build thread
Old 07-04-2015, 06:36 PM   #6
B-R-Z
B-R-Z's Avatar
Manual cc is annoying. It's too hot, then it's too cold, repeat.
Old 07-04-2015, 06:44 PM   #7
swarb
^1st world problems.
Old 07-04-2015, 09:01 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Lol I was going to say that hahahaha!!!! That being said if someone makes a retrofit kit one day I might buy it.
Old 07-04-2015, 11:03 PM   #9
Chaetagnath
Every time someone asks a question about making a change to their car that adds a feature on the limited, someone inevitably feels the need to tell them that they should have bought a limited, or they should just trade their car in for a limited blah blah blah. We get it, you were smart to buy a limited, we were all dumb buying an FRS then deciding to add something later. The OP asks a question, and the response is you should have bought a different car. Sooooo helpful, thank you for your insight. Never mind the question was about adding a feature to a car that is ALREADY owned. There couldn't ever be any other factors involved as to someone may have purchased an FRS over a BRZ?
Old 07-06-2015, 10:31 AM   #10
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
The thread has been deleted as well, or that I could find. I was able to find the thread Cached on google, but most of the pictures didn't work. I found the link to buy the harness, but was ready to give up the money for something I wasn't sure I was going to get. I also tried getting in contact with him to no avail.
DustinS is offline   Reply With Quote
Old 07-06-2015, 11:56 AM   #11
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
how did you try contacting him? i believe he has a youtube channel with a video demoing his harness.
phanguy is offline   Reply With Quote
Old 07-06-2015, 12:11 PM   #12
DustinS
DustinS's Avatar
Company email.
Seems other people haven't been able to get in touch with him either.
Old 07-06-2015, 12:28 PM   #13
phanguy
phanguy's Avatar
Company email.
oh. well i'm the first person that bought the harness from him. works well enough. footwell air stays open even if i set it to close, but that may be because i screwed up swapping parts for the one part inside. the harness itself is very straightforward and pretty easy to install. i never actually use the auto part. i LOVE having the nicer controls though. and the dual climate is SUPER nice to have because my body tends to run hot so i need more cold air than most of my passengers. would i do it again? maybe not. am i happy with it? totes.
Old 07-07-2015, 03:58 PM   #14
ort895
ort895's Avatar
ort895 is offline   Reply With Quote
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 05:46 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 01:12 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
