Old 09-27-2015, 02:23 AM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Kaotic Lazagna View Post
So much for scanning for words. LMAO. I see "button" now. But after reading through it some what more thoroughly, since messing with it solved it briefly, I still think it has something to do with the plunger.
OP swapped the door plungers/switches. Fault remained on the same side.
Old 09-27-2015, 02:31 AM   #16
Kaotic Lazagna
Drives: GR Corolla
Bad wiring behind the plunger on the affected side?
Old 09-27-2015, 02:39 AM   #17
Ultramaroon
not playing cards
That's what I'm thinking. Either that or a problem with the BCU.
Old 09-27-2015, 02:44 AM   #18
Kaotic Lazagna
Drives: GR Corolla
That would start getting beyond my knowledge.
Old 09-27-2015, 03:05 AM   #19
Ultramaroon
not playing cards
It's not that bad. Instead of the dome light being connected through the door switch, a 5 volt logic signal exists on the wire. When the door is open, the switch closes and pulls the signal to ground. The BCU senses that change and triggers all the appropriate conditions like dome light, key and/or headlight warning, blah blah blah...
If there's an internal issue keeping that signal low, the result is the same. It's a long shot, though. More likely the wiring.
Kaotic Lazagna (09-27-2015)
Old 10-21-2015, 08:51 PM   #20
meow_mix
Good kitty...
meow_mix's Avatar
Drives: Blür
Sorry, problem resolved and I've been pretty busy.
I got in my car to leave my friends house (was going to head home before I unplugged the battery) and it worked fine all the way home. It's been a month and I haven't had a single problem with it yet. I have no clue what the issue was. Maybe just a weird hiccup that finally resolved itself, or maybe some sort of wire/contact issue that is sitting just right at the moment to work. We'll see if it comes back. If so, I may start tracing wires and see what I can find.
meow_mix is offline   Reply With Quote
FS: USDM OEM Door Handles & Door Sills zeal86 Interior Parts (Incl. Lighting) 15 03-14-2016 02:33 PM
FRS door to door width customfab87 Tracking / Autocross / HPDE / Drifting 2 08-05-2015 06:11 PM
Door Ajar Light will not turn off Aznek Issues | Warranty | Recalls / TSB 15 02-02-2015 10:40 AM
Can opening door too wide cause damages to hinge/door? Weeber Scion FR-S / Toyota 86 GT86 General Forum 3 11-25-2013 11:07 AM
TRD door stabilizer and door sag.... Tromatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-25-2013 10:16 AM
