Old 09-12-2015, 08:54 PM   #1
meow_mix
Good kitty...
meow_mix's Avatar
Drives: Blür
Door Ajar won't go off - HELP
Alright, I was driving and my dome light came on because it said a door was ajar. I know it's the driver side door because the window won't roll up all the way. Can't lock the car because a "door is open". Tried pressing the door close button on the body manually and nothing. Swapped it with the passenger side button and it's still showing the driver's side door is open.
Any ideas?!
Sent from my SAMSUNG-SM-G920A using Tapatalk
meow_mix is offline   Reply With Quote
Old 09-12-2015, 11:00 PM   #2
humfrz
So, when the door is open and you press in the button on the door jam, does the window move a little ... ??
Have you checked the positions #10, 24 & 36 fuses (box under the hood)...??
humfrz
humfrz
Old 09-13-2015, 02:38 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
If I'm correctly reading the wiring diagram, the door ajar switches go straight to dedicated channels on the BCU. An open door pulls a logic signal to ground. Either that wire must be shorted to ground somewhere, or the fault lies in the BCU itself.
I don't know how long the battery must be disconnected before everything resets itself but maybe try disconnecting it for a few minutes and then see if that doesn't reset the BCU.
It's a long shot.
@steve99 posted a link to the wiring diagram in another post tonight. Check out page 268.
humfrz (09-13-2015)
Old 09-13-2015, 03:47 AM   #4
steve99
Id go to page 185 (or 268), front dooor switch signals BCU directly if dome light on and dash door indicator indicator on and window stuch down it looks like short to earth on G18 or H21 switch assembly or wiring.
remove offending switch assembly from door and disconnect see if light goes out if your lucky its just a stuffed door switch, then next best is short to earth in wiring and worst case is stuffed BCU (body control unit )
unlikely to be a fuse as you would get no light.
unlikely to be short to earth on courtesy light side as BCU would not get signal to indicate door ajar
It appears BCU is being signaled that door is permanently open most likely is stuffed door switch
Sportsguy83 (09-28-2015)
Old 09-13-2015, 10:50 AM   #5
meow_mix
Good kitty...
meow_mix's Avatar
Drives: Blür
Alright, after swapping the door ajar buttons the problem persisted on rhe driver's side. After some fiddling, it went away. Drove home fine. This morning it came back on, then went off after messing with rolling the windows up and down. Gonna try and unplug the battery for a bit. :/
Old 09-13-2015, 01:23 PM   #6
Ultramaroon
not playing cards
After reading that your problem is intermittent, I have less faith in it being a software issue but the battery disconnect is cheap. Don't forget that will also reset your ECU so throttle response will be shitty for a while. Don't freak out about that.
I did catch in your OP that you swapped the switches so those are fine. It's a messy but short trip for a single conductor from the switch to the BCU.
Old 09-25-2015, 11:41 PM   #7
Ultramaroon
not playing cards
@meow_mix, updates?
Old 09-26-2015, 02:18 AM   #8
Kaotic Lazagna
Drives: GR Corolla
Can it be the door plunger?
Old 09-26-2015, 08:53 AM   #9
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
doesn't the trunk throw the "door ajar" light up? I know you think you have it narrowed down to the door but give it a whirl. if the trunk doesn't actually kick that light on, ignore me as i'm still drunk
cdq85 is offline   Reply With Quote
Old 09-26-2015, 02:11 PM   #10
humfrz
DANG, Kaotic Lazagna ...... we know what ol cdq85's excuse is (see above) .... what's yours ..... ??
Maybe you were at the same party ......??
humfrz
Old 09-26-2015, 07:20 PM   #11
Kaotic Lazagna
Drives: GR Corolla
Lol. That was a legitimate question.
Old 09-26-2015, 07:27 PM   #12
Ultramaroon
not playing cards
Not if you had read the whole thread.
Old 09-26-2015, 09:48 PM   #13
Kaotic Lazagna
Drives: GR Corolla
I just read stuff about fuses. Don't recall seeing plunger. Haha
Old 09-26-2015, 11:33 PM   #14
Kaotic Lazagna
Drives: GR Corolla
So much for scanning for words. LMAO. I see "button" now. But after reading through it some what more thoroughly, since messing with it solved it briefly, I still think it has something to do with the plunger.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Ultramaroon (09-27-2015)
FS: USDM OEM Door Handles & Door Sills zeal86 Interior Parts (Incl. Lighting) 15 03-14-2016 01:33 PM
FRS door to door width customfab87 Tracking / Autocross / HPDE / Drifting 2 08-05-2015 05:11 PM
Door Ajar Light will not turn off Aznek Issues | Warranty | Recalls / TSB 15 02-02-2015 09:40 AM
Can opening door too wide cause damages to hinge/door? Weeber Scion FR-S / Toyota 86 GT86 General Forum 3 11-25-2013 10:07 AM
TRD door stabilizer and door sag.... Tromatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-25-2013 09:16 AM
