Old 08-17-2015, 04:13 PM   #15
stugray
Drives: 2013 GBS BRZ Limited
WOW! My first impression of this thread is somewhat like:
"I want to go to the moon.
I have a Soviet Buran, and a box of estes rocket engines, How do I hook it up?"
After reading just the first post I thought to myself: "Is there even room in the footwell for a Tilton bias box with dual master cylinders"
Then I thought "How in the hell could you install an aftermarket MC system, but retain the ABS?"
Tell the Cheshire cat I said hello while you are down there....
Old 08-18-2015, 01:01 PM   #16
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Originally Posted by puma View Post
you will lose you speed sensors if you remove it completly, you need to keep the electronic part of the ABS plugged in, this is what we did but eliminated the whole tubing side of it.
How did you get rid of the engine management light on the dash? I think maybe the engine will go to limp mode if that light stays on??
This whole project is steering big time towards Motec.
Nigelr32 is offline   Reply With Quote
Old 08-18-2015, 02:41 PM   #17
stugray
I thought about this some more, and the #1 thing that needs to be done (before buying parts) is to make a diagram of the brake system.
Include lots of pictures and assumptions about how the system works.
Since the system has VSC (it can APPLY brakes as well as release them) it must be able to release/re-pressurize the system without pumping the brakes.
How does it do that?
Does the ABS valve manifold have a separate Input for each caliper, or is it a manifold and has one IN for front & one IN for rear?
Is there ONE MC for Front & ONE MC for rear?
Are The Master Cylinder(s) co-linear (like in my Porsche) or side by side (like in my Triumph)?
Does the system have Pressure sensors for each circuit, or one for each caliper?
Those are all the types of questions that need to be answered, and that all I could think of in 2 minutes.
There are many more for a system as complex as this.
There is no simple answer and not just one way to do it.
Old 08-18-2015, 03:25 PM   #18
Nigelr32
How does it do that? By using the pump in the module to create fluid pressure
Does the ABS valve manifold have a separate Input for each caliper, or is it a manifold and has one IN for front & one IN for rear? It has one in for FR and RL and one input for FL and RR.
Is there ONE MC for Front & ONE MC for rear? It is a double MC with two pistons, split as mentioned above. The pistons are both 1" diameter.
Are The Master Cylinder(s) co-linear (like in my Porsche) or side by side (like in my Triumph)? Co-linear, one behind the other.
Does the system have Pressure sensors for each circuit, or one for each caliper? The system has sensors for each caliper. The car has an individual line to each wheel.
I'm not sure there's any way to do it my friend. I love your signature.. I am an Engineer.
Old 08-18-2015, 06:23 PM   #19
puma
crew chief
puma's Avatar
Drives: Race car FR-S
we didn't get rid of it and we couldn't care less about it, it is a race car with a MXL in front of it, we kept the dash because car won't start without it but otherwise we would have taken it out.
We have ABS, trac, VSC, Air bag, check engine, anything that can be lit is.
Our engine never went in limp mode.
puma is offline   Reply With Quote
Old 08-18-2015, 06:52 PM   #20
Nigelr32
I love you guys. You're attitude is just fantastic!! Thank you very much for your replies!!
Old 08-18-2015, 10:40 PM   #21
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
For those who don't have it already, here's the BRZ wiring diagram:
http://www.ft86club.com/files/BRZwiringi.pdf
It's got alot of valuable information, if you've got the patience to decypher it. On page 220 - 222, it shows the VSC/VDC module wiring.
Here are the inputs:
- 4 x wheel speed sensors (2 wires each)
- CAN bus signal (low + high)
- VSC OFF trigger
- VSC Sport trigger
- brake light voltage (filtered)
- 2 x ground wire
- 2 x un-switched B+
- switched B+ (IGN)
That's it. The module can pull lots of info from the CAN bus, but it seems to be pretty self-contained.
With regard to accelerometers, we have quite a few... but they appear to be collision sensors. Left side front bumper, right side front bumper, left A pillar, right A pillar, left door, right door, left rear qp, right rear qp, and under the back seats. The manual has a good explanation of how the SRS decides which airbag to deploy.
Not sure if these are sensitive enough for ABS/EBFD/VSC/TRAC use.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 08-19-2015, 05:27 AM   #22
Nigelr32
Thanks for this valuable information. I have removed all the ABS sensors shown in your diagram above, but am wondering what number one is?
What would be your feeling if I removed the Can bus wiring?? It is probably this which triggers the dash lights?
Old 08-19-2015, 05:29 AM   #23
Nigelr32
What is MXL?
Old 08-19-2015, 06:24 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
Maybe this if mentioned alongside dash?
Old 08-19-2015, 07:46 AM   #25
puma
crew chief
puma's Avatar
yeah sorry, AIM MXL dash
Old 08-19-2015, 09:05 AM   #26
Shankenstein
Frosty Carrot
I think that's the pretensioner on the seat belt. The diagram is from an ebay listing without much detail. It shows all of the different sensors and actuators in the SRS (not the control modules).
Old 08-20-2015, 04:19 AM   #27
Nigelr32
Having given the last mail some thought, I can confirm that these sensors do not affect the ABS or VSC.
I know of two cars in this country running without them and everything works fine.
Wilwood BBK for WRX - Fit to BRZ swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 05-03-2019 06:41 PM
WRX rear wilwood would it fit? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-22-2013 09:26 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
