Old 05-20-2013, 09:56 PM   #1
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
WRX rear wilwood would it fit?
Do you guy's think that this rear wilwood brake kit from a Subaru WRX kit will fit?
http://www.wilwood.com/BrakeKits/Bra...%2c+except+STI
I see that some need to use those KNS adapter barcket to fit WRX/STI rear brake so maybe I will need those also?
http://www.knsbrakes.com/carItemDeta...&item_id=37648
I ask this because I got option to get some for really cheap second hand.
So would like to fir those with the front WRX wilwood 12"
SO for less than 1500$ I will get front and rear wilwood this should remove lot of weight and be enough for me.
Mars2 is offline   Reply With Quote
Old 05-20-2013, 10:49 PM   #2
Mars2
Ok found out it will not work because hand brake have different diameter.
Old 05-22-2013, 01:07 AM   #3
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Well shit.....there goes that plan. Thanks for letting us know. I'm assuming it's safe to say that from here on out, that all WRX rear brake kits won't fit as a result. Maybe a piece here n there, but not the whole thing.
omegared19 is offline   Reply With Quote
Old 05-22-2013, 04:41 AM   #4
Mars2
look like the last version 2010 will fit exacte same part number as the BRZ kit. but also same price
Old 05-22-2013, 04:48 AM   #5
Mars2
I mean WRX 08-12 will fit same size e brake
Old 05-22-2013, 09:26 AM   #6
OrbitalEllipses
Drives: Attitude
A GD chassis rear kit would be a waste unless you got it used on the cheap. You'd need the 08+ rear rotor anyway (190mm parking brake) and a bracket to fit the caliper to the knuckle in the proper orientation.
Wilwood BBK for WRX - Fit to BRZ swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 05-03-2019 06:41 PM
Wilwood Big Brake Kit Installed msile Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 03-03-2014 02:00 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
