#15 |
Drives: 2013 BRZ Limited Turbo E85
Its actually a v mount for an RX-7. I'll have to look up the company I ordered it from.
#16 |
igotthatpurp
did you have to change the piping or still using the same one from the original kit?
#17 |
All piping stayed the same. Just tweaked their position a little, got some couplers, and cut them to fit the pipes.
#18 |
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Keep up the good work bro. Post up the before and after dyno videos when you can.
#19 |
Drives: 2013 Scion FRS
Still no clue on what brand intercooler that is?
#20 |
Drives: 2015 brz
Very nice, keep up the work!
#21 |
igotthatpurp
#22 |
Drives: 2015 Subaru BRZ
Is the turbo mounted to anything substantial or just sitting on the exhaust manifold and downpipe?
#23 |
Sorry for the late response. Been super busy. I don't have the site I ordered it from bookmarked anymore, but its a TRE performance I believe. I had to modify it a little.... cut brackets off...weld some bungs...etc....nothing major. They use a garrett style core. Hope this helps.
#24 |
Its mounted the same way the greddy turbo was. Still utilizes the greddy support brackets that hold everything to the motor. It was a direct fit on the turbine housing end.
#25 |
Drives: 2015 brz
nice
#26 |
Drives: Asphalt FR-S MT
Just curious why didn't you go with the gtx28?
#27 |
Any dyno charts to compare to your last setup or are you still running an e-tune?
#28 |
I actually talked about that in the first paragraph of the original post. The gtx turbos don't really come alive below 20psi (they are actually restrictive at lower boosts) and the other gt28r turbos were comparable to the t518z the kit originally came with. I wanted a turbo that could flow a good amount at 15-16psi with room to grow later.
| FS:A Garrett turbo,& a Greddy turbo kit with extra parts. | Cessblood | Engine, Exhaust, Bolt-Ons | 76 | 02-18-2015 08:47 AM |
| Fs: custom turbo setup. GT3076R and more | glorydays | Engine, Exhaust, Bolt-Ons | 32 | 11-11-2014 10:47 PM |
| PTuning Turbo Kit GT3076R BNIB + 3" Exhaust | sw20kosh | Engine, Exhaust, Bolt-Ons | 22 | 02-21-2014 02:24 PM |
| PRE turbo kit (garrett GT3076R) | BRZPDX | Northwest | 90 | 01-18-2014 10:39 AM |
| PTUNING GT3076R 9 PSI Preliminary 93 Pump Gas Tune | ptuning | Forced Induction | 35 | 08-06-2013 02:59 PM |
