Old 11-07-2014, 09:14 PM   #1
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Fs: custom turbo setup. GT3076R and more
$2200obo. Up for sale is my custom built turbo setup. It is a near battery mounted Garrett gt3076r with precision housings. The turbine housing is a dsm flanged 20g sized and the compressor housing is .60ar. I had it installed for around 15k miles before I removed it to have the uppipe reworked then I never got around to reinstalling it. I'm selling because I'm trading my brz for a new wrx (time to grow up... a little). I was never able to get hp figures but with the right tuning you should be around 270whp if not more. This setup allows you to retain the factory exhaust system with the exception of the over pipe. It is a blow through system with an Omni 3 bar MAP sensor. The FMIC allows you to keep the washer bottle in its factory location. The turbocharger sits slightly above the engine allowing the oil return to gravity drain into the rear cam plate so you won't have to tap your oil pan. You will have everything you need to have a boosted FRS or BRZ.
Included in the kit:
Garrett gt3076r
2.25in. Uppipe
2.25in. Downpipe
Tial 38mm wastegate with 7psi spring
Turbosmart Vee port pro BOV
FMIC with 2.5in charge pipes
Map pipe with flange
PTuning cam plate for oil return
Oil and water fittings and hoses
SS braided oil feed sourced from front oil galley plug
Aem failsafe Guage and wideband
Vent pod to mount wideband gauge
Vacuum block
Battery heat shielding plate
Extra 4 ply silicone couplers and t bolt clamps
glorydays is offline
The Following User Says Thank You to glorydays For This Useful Post:
carlossanchez89 (11-07-2014)
Old 11-07-2014, 10:00 PM   #2
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
what the hell?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
The Following User Says Thank You to Boofneenee For This Useful Post:
D_Thissen (11-07-2014)
Old 11-07-2014, 11:01 PM   #3
D_Thissen
D_Thissen's Avatar
Interested in AEM failsafe and vent pod
D_Thissen is offline
Old 11-08-2014, 08:47 AM   #4
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
What does the FMIC look like through the grill?
FRS
Old 11-08-2014, 09:59 AM   #5
raven1231
Price???
raven1231 is offline
Old 11-08-2014, 11:29 AM   #6
glorydays
Remember me?
glorydays's Avatar
Can't see it much other than the clamps on the right side.
Old 11-08-2014, 11:30 AM   #7
glorydays
Remember me?
glorydays's Avatar
Price???
Looking for $2500 shipped.
Old 11-08-2014, 12:37 PM   #8
raven1231
Very interested what did you use for tuning ? And is that for sale?
Old 11-08-2014, 02:26 PM   #9
glorydays
Remember me?
glorydays's Avatar
@raven1231 I have ecutek so unfortunately I can't sell the license with the kit. If I had to do it again I'd go with oft for resale value.
Old 11-08-2014, 02:36 PM   #10
raven1231
I have an OFT. Is it able to tune custom kits like this?
Old 11-08-2014, 04:50 PM   #11
raven1231
Also what was wrong with the uppipe?
Old 11-08-2014, 05:25 PM   #12
glorydays
Remember me?
glorydays's Avatar
From what I've read the oft either does or is close to having wideband compatibility so a competent tuner should be able to. My basemap was done on ecuflash and oft tuned the sbd kit so it's definitely possible.
also the uppipe was too close to the cam plate and frame so I had it re-welded.
raven1231 (11-08-2014)
Old 11-08-2014, 05:34 PM   #13
raven1231
Pm'd
Old 11-08-2014, 06:14 PM   #14
FirestormFRS
You've been running unfiltered air through that car for how long? Or I'm missing something
FirestormFRS is offline
boost, turbo, turbo brz, turbo kit
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
PTuning Turbo Kit GT3076R BNIB + 3" Exhaust sw20kosh Engine, Exhaust, Bolt-Ons 22 02-21-2014 02:24 PM
PRE turbo kit (garrett GT3076R) BRZPDX Northwest 90 01-18-2014 10:39 AM
