Old 06-07-2015, 11:47 PM   #15
boostedbrz
boostedbrz's Avatar
Drives: 2013 BRZ Limited Turbo E85
Its actually a v mount for an RX-7. I'll have to look up the company I ordered it from.
boostedbrz is offline   Reply With Quote
Old 06-08-2015, 09:07 AM   #16
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
did you have to change the piping or still using the same one from the original kit?
FRS-HHH is offline   Reply With Quote
Old 06-08-2015, 09:14 AM   #17
boostedbrz
boostedbrz's Avatar
All piping stayed the same. Just tweaked their position a little, got some couplers, and cut them to fit the pipes.
The Following User Says Thank You to boostedbrz For This Useful Post:
FRS-HHH (06-08-2015)
Old 06-08-2015, 01:01 PM   #18
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Keep up the good work bro. Post up the before and after dyno videos when you can.
Cessblood is offline   Reply With Quote
The Following User Says Thank You to Cessblood For This Useful Post:
boostedbrz (06-08-2015)
Old 06-08-2015, 11:38 PM   #19
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Still no clue on what brand intercooler that is?
RD1428 is offline   Reply With Quote
Old 06-09-2015, 08:02 PM   #20
Streetthrowback
Drives: 2015 brz
Very nice, keep up the work!
Streetthrowback is offline   Reply With Quote
Old 06-09-2015, 08:05 PM   #21
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
and the company he got it from lol
Old 06-09-2015, 08:41 PM   #22
IBill4You
Drives: 2015 Subaru BRZ
Is the turbo mounted to anything substantial or just sitting on the exhaust manifold and downpipe?
IBill4You is offline   Reply With Quote
Old 06-09-2015, 11:12 PM   #23
boostedbrz
boostedbrz's Avatar
Sorry for the late response. Been super busy. I don't have the site I ordered it from bookmarked anymore, but its a TRE performance I believe. I had to modify it a little.... cut brackets off...weld some bungs...etc....nothing major. They use a garrett style core. Hope this helps.
Old 06-09-2015, 11:14 PM   #24
boostedbrz
boostedbrz's Avatar
Its mounted the same way the greddy turbo was. Still utilizes the greddy support brackets that hold everything to the motor. It was a direct fit on the turbine housing end.
The Following 2 Users Say Thank You to boostedbrz For This Useful Post:
Cessblood (06-11-2015), IBill4You (06-09-2015)
Old 06-09-2015, 11:36 PM   #25
Streetthrowback
Drives: 2015 brz
nice
The Following User Says Thank You to Streetthrowback For This Useful Post:
boostedbrz (06-10-2015)
Old 07-08-2015, 10:05 PM   #26
kcam86
Drives: Asphalt FR-S MT
Just curious why didn't you go with the gtx28?
kcam86 is offline   Reply With Quote
Old 07-08-2015, 10:28 PM   #27
IBill4You
Any dyno charts to compare to your last setup or are you still running an e-tune?
Old 08-11-2015, 05:38 AM   #28
boostedbrz
boostedbrz's Avatar
I actually talked about that in the first paragraph of the original post. The gtx turbos don't really come alive below 20psi (they are actually restrictive at lower boosts) and the other gt28r turbos were comparable to the t518z the kit originally came with. I wanted a turbo that could flow a good amount at 15-16psi with room to grow later.
Cessblood (08-11-2015)
FS:A Garrett turbo,& a Greddy turbo kit with extra parts. Cessblood Engine, Exhaust, Bolt-Ons 76 02-18-2015 08:47 AM
Fs: custom turbo setup. GT3076R and more glorydays Engine, Exhaust, Bolt-Ons 32 11-11-2014 10:47 PM
PTuning Turbo Kit GT3076R BNIB + 3" Exhaust sw20kosh Engine, Exhaust, Bolt-Ons 22 02-21-2014 02:24 PM
PRE turbo kit (garrett GT3076R) BRZPDX Northwest 90 01-18-2014 10:39 AM
PTUNING GT3076R 9 PSI Preliminary 93 Pump Gas Tune ptuning Forced Induction 35 08-06-2013 02:59 PM
