Old 07-03-2013, 12:17 PM   #1
ptuning
ptuning's Avatar
Drives: White FR-S
PTUNING GT3076R 9 PSI Preliminary 93 Pump Gas Tune
We've had a lot of folks ask us what our upcoming turbo system will make at higher boost levels on pump gas. Here is a preliminary 9 psi tune. By preliminary, we mean we didn't spend too much time dabbling with optimizing the tune since we went with WMI shortly after. We'll likely revisit the 8, 9, and 10 psi numbers once we start our local install/tunes for customers who have pre-ordered our set-up.
Note that the tune is knock limited on the 93 pump gas and cannot be tuned for MBT at the power levels that we are at.
Also, for reference, please keep in mind that our Dyno Dynamics Dyno reads 10-12% lower than a Dynojet.....something that a lot of the Vortech and Innovate SC guys will attest to. We'll let you guys do your own math though to figure out what we'd likely be putting down on a Dynojet.
ptuning is offline   Reply With Quote
Old 07-03-2013, 12:48 PM   #2
Raven604
Which turbo is that again?
Edit: lol its in the title
Raven604 is offline   Reply With Quote
Old 07-03-2013, 12:50 PM   #3
sw20kosh
Drives: 2013 Black FR-S
Old 07-03-2013, 12:51 PM   #4
superstani
Drives: 12 TL
I believe its in the title gt3076R
Any other modification besides the turbo kit?
superstani is offline   Reply With Quote
Old 07-03-2013, 01:25 PM   #5
nonicname
Drives: it has 4 wheels and a motor
I'm glad to see people are testing real gas and not california water.
nonicname is offline   Reply With Quote
Old 07-03-2013, 01:48 PM   #6
ptuning
ptuning's Avatar
Drives: White FR-S
The only mod we have is a 3" V-band exhaust system. Something we highly recommended with any FI application for the FR-S/BRZ.
Other required supporting mods:
Larger FIC port injectors
4 Bar MAP sensor
Exedy Stage 1 clutch
We're running the stock (untouched) fuel pump/assembly.
Old 07-03-2013, 01:51 PM   #7
ft_sjo
Drives: GT86
You say you're det limited, how much advance are you able to run on the top line?
Old 07-03-2013, 02:08 PM   #8
ptuning
ptuning's Avatar
Drives: White FR-S
I don't remember the exact numbers off the top of my head, but the timing values are disproportionally lower as the boost goes from 4 psi (MBT tuneable) to 9 psi.
Adding WMI to the mix as allows us to add 3-4 degrees of timing at the same boost levels, thereby allowing us to reach MBT at these mid boost levels.
Old 07-03-2013, 02:36 PM   #9
ft_sjo
Drives: GT86
Fair enough, I like to keep my spark angles above 12 degrees to avoid high EGT's. Just wondering what kind of territory this power level is in on 93 aki fuel.
Old 07-03-2013, 02:41 PM   #10
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
Can't see the chart its blocked here in the Stan. what'd it make?
Syldrin is offline   Reply With Quote
Old 07-03-2013, 02:45 PM   #11
ptuning
ptuning's Avatar
Drives: White FR-S
318.7 whp
257.1 wtq
Old 07-03-2013, 02:53 PM   #12
Syldrin
Troll Feeder
Syldrin's Avatar
.82 A/R?
Old 07-03-2013, 03:53 PM   #13
sw20kosh
Not only does it allow more timing but you are able to bump up the boost like 30% more? or 50% more? Untill you are knock limited again.
Old 07-04-2013, 01:12 AM   #14
kanundrum
Drives: 2013 Whiteout FR-S
Awesome
OTD pump gas Ecutek tune - 182rwhp + 145wtq ultra Engine, Exhaust, Transmission 43 11-01-2014 02:50 PM
Visconti Tune STG 1 Pump Gas Help Cal3000 Engine, Exhaust, Transmission 7 05-05-2013 08:36 PM
Visconti Stage 1 NA Tune Pump & e85 Review CBR600RR Engine, Exhaust, Transmission 22 04-26-2013 10:36 AM
FA20club.com E85 Preliminary Review JoeBoxer Engine, Exhaust, Transmission 130 12-10-2012 11:01 AM
