#16 |
Drives: scion frs
I know Im depressed lol
#17 |
Drives: Raven
other cars nearby had similar stain as yours had more crap stain, pigeons?
something smelly, and you still have crickets.. |
#18 | |
![]() Yep, like said above, if you're going to crank it up, take it out and drive it for at least 10-20 miles. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ricky rod (05-29-2015) |
#19 |
Salt! So, so much salt!
| The Following User Says Thank You to Tcoat For This Useful Post: | HunterGreene (05-29-2015) |
#20 |
Drives: scion frs
[QUOTE]Yep, like said above, if you're going to crank it up, take it out and drive it for at least 10-20 miles.
How often I need to do that? |
#21 | |
[quote=ricky rod;2266531]
Another reason to run it longer is to make sure you are heating the exhaust enough to dry it out. There is always some moisture pulled through the system in humid climates (I am lead to believe it can be humid in Florida) and if the exhaust is not warm enough to evaporate it than it just sits inside and starts to rust out any non stainless components.
| The Following User Says Thank You to Tcoat For This Useful Post: | ricky rod (05-29-2015) |
#22 |
Holy baby Jesus can I have your garage. Please? Pretty Please? lol
#23 | |
Drives: '23 BRZ Limited
[quote=Tcoat;2266571]
Also, H2O is a by-product of combustion, then condensation as the exhaust cools down, etc. |
#24 |
[quote=OkieSnuffBox;2266602] Exactly.
#25 | |
OP, I'd suggest you take it for a spin at least once every other month (however, I have no data to support that). As mentioned before, don't forget about the gas stabilizer ...... that tank of gas will get really old before you take the cosmoline off of the car ..... ![]() humfrz |
#26 |
Drives: scion frs
Wao and I keep learning... Thank you guys!!!!
| The Following User Says Thank You to ricky rod For This Useful Post: | Tcoat (05-29-2015) |
#27 |
Off Topic
Question about gas in cars in storage, since mine will be doing that shortly.
I know ethanol degrades after a while and clogs fuel systems, but if I run it way down and then fill up with ethanol-free gasoline right before putting the car down for storage will there be an issue? Or do I just dump in a bottle of stabil and not worry about it? The only ethanol-free gas around here is 100 octane, which makes for quite an expense. |
#28 | |
Just run regular E10, run it long enough the E85 is out of the tank, and drop in a bit of Stabil, you'll be fine. I've literally let E10 gas sit in a project car for a year, when we were done, we topped it off and took it to the track, ran fine with no problems. The E10 thing is blown WAY out of proportion. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | gramicci101 (05-29-2015) |
| New to rim fitment; someone please advise | REAV3R | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 03-02-2015 09:02 PM |
| Looking for advise on buying the frs | Antairez | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 02-11-2015 06:33 PM |
| FT86 advise please | eddiev116 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-01-2015 04:13 PM |
| Guys I can really use some advise... | ScionFrsFan | Engine, Exhaust, Transmission | 27 | 12-31-2012 12:03 PM |
| Advise On Purchasing Fr-s Please! | 7EASTAP | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-18-2012 06:45 PM |
