Old 05-28-2015, 08:50 PM   #15
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
My life would be so sad if I couldn't daily drive my BRZ...
Aozora.BRZ is offline   Reply With Quote
Old 05-28-2015, 09:13 PM   #16
ricky rod
ricky rod's Avatar
Drives: scion frs
I know Im depressed lol
Name:  the_road_is_calling_me_coffee_mug_mug-ref36beea83bc408aa9db1008854ab7d0_x7jgr_8byvr_324.jpg
ricky rod is offline   Reply With Quote
Old 05-29-2015, 12:34 AM   #17
SR5
SR5's Avatar
Drives: Raven
HOLY CRAP!
That is nicer than my living room. I am not kidding here!
And just for perspective DD, 4,000 miles a month, never been inside :
other cars nearby had similar stain as yours had more crap stain, pigeons?
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
Old 05-29-2015, 01:00 AM   #18
Originally Posted by ricky rod View Post
yea I keep it in the garage all the time and only take it out around the block one time a month for like 5 minutes to run the fluids...
Attachment 110727
That garage is disgusting ...... you’re one sick puppy ……
Yep, like said above, if you're going to crank it up, take it out and drive it for at least 10-20 miles.
ricky rod (05-29-2015)
Old 05-29-2015, 05:48 AM   #19
Salt! So, so much salt!
HunterGreene (05-29-2015)
Old 05-29-2015, 07:00 AM   #20
ricky rod
ricky rod's Avatar
Drives: scion frs
[QUOTE]Yep, like said above, if you're going to crank it up, take it out and drive it for at least 10-20 miles.
How often I need to do that?
Old 05-29-2015, 08:30 AM   #21
[quote=ricky rod;2266531]
The more often the better actually.
Another reason to run it longer is to make sure you are heating the exhaust enough to dry it out. There is always some moisture pulled through the system in humid climates (I am lead to believe it can be humid in Florida) and if the exhaust is not warm enough to evaporate it than it just sits inside and starts to rust out any non stainless components.
Old 05-29-2015, 08:37 AM   #22
Pkush
Holy baby Jesus can I have your garage. Please? Pretty Please? lol
Pkush is offline   Reply With Quote
The Following 2 Users Say Thank You to Pkush For This Useful Post:
PWBRZ (06-19-2015), ricky rod (05-29-2015)
Old 05-29-2015, 09:10 AM   #23
OkieSnuffBox
Drives: '23 BRZ Limited
[quote=Tcoat;2266571]
Also, H2O is a by-product of combustion, then condensation as the exhaust cools down, etc.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
ricky rod (05-29-2015), Tcoat (05-29-2015)
Old 05-29-2015, 09:21 AM   #24
[quote=OkieSnuffBox;2266602]
Exactly.
Old 05-29-2015, 10:59 AM   #25
Good point about a good warm up.
OP, I'd suggest you take it for a spin at least once every other month (however, I have no data to support that).
As mentioned before, don't forget about the gas stabilizer ...... that tank of gas will get really old before you take the cosmoline off of the car .....
Old 05-29-2015, 11:19 AM   #26
ricky rod
ricky rod's Avatar
Drives: scion frs
Wao and I keep learning... Thank you guys!!!!
The Following User Says Thank You to ricky rod For This Useful Post:
Tcoat (05-29-2015)
Old 05-29-2015, 11:29 AM   #27
gramicci101
Off Topic
Question about gas in cars in storage, since mine will be doing that shortly.
I know ethanol degrades after a while and clogs fuel systems, but if I run it way down and then fill up with ethanol-free gasoline right before putting the car down for storage will there be an issue? Or do I just dump in a bottle of stabil and not worry about it? The only ethanol-free gas around here is 100 octane, which makes for quite an expense.
Old 05-29-2015, 11:55 AM   #28
OkieSnuffBox
Just run regular E10, run it long enough the E85 is out of the tank, and drop in a bit of Stabil, you'll be fine.
I've literally let E10 gas sit in a project car for a year, when we were done, we topped it off and took it to the track, ran fine with no problems.
The E10 thing is blown WAY out of proportion.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
gramicci101 (05-29-2015)
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 08:02 PM
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 05:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 03:13 PM
Guys I can really use some advise... ScionFrsFan Engine, Exhaust, Transmission 27 12-31-2012 11:03 AM
Advise On Purchasing Fr-s Please! 7EASTAP Scion FR-S / Toyota 86 GT86 General Forum 7 09-18-2012 05:45 PM
