Old 03-28-2016, 08:31 PM   #15
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'm currently springless and dislike the looseness of the clutch when let off at top, I ended up bringing the cruise control sensor down a bit until it held the clutch steady. The sensor itself works fine still. But the clutch master seals wearing does sound scary.
EDIT: holy crap, $27 for the spring!? :/
tracerit is offline   Reply With Quote
Old 01-30-2017, 05:38 PM   #16
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Has anyone else used this clutch spring? I removed my stock spring last week and like the feel. But it's a little much sitting in rush hour traffic 5 days a week. I thought this spring might be a good balance between the stock spring and no spring at all.
smg1138 is offline   Reply With Quote
Old 02-15-2017, 09:49 PM   #17
scottbrz
Drives: 2017 BRZ Limited PP
Despite having driven manual transmission vehicles for over 20 years, my 2016 BRZ will at times make me look like a stickshift newbie. It's a little strange, sometimes I'm on point and am clicking off flawless shifts; other times I'm lurching like a 16 year old.
I attributed this to a few factors:
* lack of clutch feel
* lazy throttle (as compared to my old throttle-cabled NB miata)
* unintuitively high clutch engagement
* myself
I installed the mtec spring this past weekend (first mod) and have driven with it enough to make some statements on it.
Install:
Getting the stock spring out took some doing and is a bit awkward, but it eventually came out. Getting the mtec spring back in was much easier.
Weight:
Clutch effort will be higher. You'll notice it most on your first test drive. After a few days, I've completely adjusted to it. It now feels totally normal to me. I don't find it to be tiring, even in stop & go traffic.
Feel:
Clutch feel is notably improved. Shifting my BRZ is now easier, and I don't look like a newb nearly so much as I used to. But, this is not a cure-all. I still fall into a poor shifting bout from time to time, usually when trying to drive sedately.
Conclusion:
This is worthwhile if you find your BRZ to be lacking in clutch feel, and don't want any slop from a springless system. I'd do it again.
scottbrz is offline   Reply With Quote
The Following 6 Users Say Thank You to scottbrz For This Useful Post:
Plumbus (07-15-2020), smg1138 (03-20-2017), SubieRumble (02-16-2017), swarb (02-15-2017), TofuJoe (01-23-2018), tony-brz (07-26-2017)
Old 10-03-2017, 02:47 PM   #18
Anthonyc77
Drives: 2017 Toyota 86 Halo
Just installed the MTEC clutch spring on my 2017 86. I used a tiny flat head to pop the c-clip out, and a large flat head for the rest. Install was fairly straight forward with the included zipties. Took me just 15 minutes from start to finish.
For my impressions, to start lets just say I had the same complaints as everyone else. Car made me feel like a novice at manual (mainly at low speeds, would get some jerks as I would think the clutch was disengaged when it wasnt). Especially evident when switching back and forth between a miata which is one of the easiest manual cars I have ever driven. The spring definitely helps with feeling the engagement, and is much better for slower speeds. The engagement still isnt as smooth as my miata, but it is heaps better than it was.
Without trying "no spring" to compare, its hard to say if this would be a huge improvement over that for the price. But I did notice very minimum deadplay with the mtec spring which seems to be one of the main complaints of the spring removed. I would say give no spring a shot, and if you can't live with the deadplay, this is a better alternative then adjusting the clutch switch (which could have detrimental effects if you adjust it to far out and get slight drag on the clutch without realizing)
Anthonyc77 is offline   Reply With Quote
Old 01-23-2018, 01:37 AM   #19
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
Thank you all for the reviews on this. Between these and my coworker I put this in last night and this is the feel that I've been missing the fast few years I've had BRZ's. I really thought they'd fix it with the '17 but it was still just as bad. You can tell exactly where the engagement point is now instead of dealing with an overcompressed spring simulating the same feel as the engagement point. Seriously, get it. $30 is definitely overpriced but well worth the investment nonetheless
texastwurkt3am is offline   Reply With Quote
The Following 3 Users Say Thank You to texastwurkt3am For This Useful Post:
funwheeldrive (03-02-2018), gravitylover (01-23-2018), jcw99 (02-03-2018)
Old 04-16-2023, 10:27 AM   #20
r4mr4m3024
Drives: gt86
In your opinion, is it effective to cover the same stock spring with two zippers without removing it or not?
r4mr4m3024 is offline   Reply With Quote
Old 04-16-2023, 11:28 AM   #21
MConte05
Drives: 2023 GR86
I just posted in another thread about how GKTech released some GT86 stuff, but they also have MUCH more reasonably priced springs for the Clutch and Shifter:
https://us.gktech.com/86-fr-s-brz-clutch-pedal-springs
https://us.gktech.com/86-fr-s-brz-tr...urn-spring-kit
MConte05 is offline   Reply With Quote
The Following User Says Thank You to MConte05 For This Useful Post:
jcw99 (04-26-2023)
Old 04-22-2023, 04:26 PM   #22
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I did this mod a while back combined with adjusting the clutch petal so its sits slightly lower for better foot placement. I also did the mtec shift springs, weighted shift knob, and a poly rear shifter bushing. Overall, the combo makes it a much better experience than stock. I can actually feel the engagement and the knob is much better getting into gear and out of gear.
I've seen that some have also replaced the clutch slave cylinder with one from an imprezda or wrx for a shorter throw, but it makes the petal even heavier. I don't think it would be ideal for daily with the mtec clutch spring or no spring in combo with a higher torque rated clutch disk.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 04-23-2023, 06:01 AM   #23
r4mr4m3024
Drives: gt86
Hi, What is the wire diameter size of this spring? Also its width and height
Old 04-26-2023, 06:48 AM   #24
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I found this information in another post and I bought some on Aliexpress 🤣
largo 50.8mm 2in
comprimido 20.82mm 0.82in
ancho 24.63mm 0.97in
interior 19.3mm 0.76in
hilo 2.66mm 0.105in
I bought the MTEC of the transmission, but I did not want to spend the ridiculous shipping costs and tariffs for one for the clutch.
Ruben_86_ is offline   Reply With Quote
MTEC Shifter Spring Questions & Comments JohnAyySays Engine, Exhaust, Transmission 19 06-11-2018 09:09 AM
Need help - stripped mtec spring stueck9356 Engine, Exhaust, Transmission 45 04-30-2017 10:14 PM
Yet another Mtec shift Springs review Raven604 Engine, Exhaust, Transmission 19 10-05-2016 09:04 PM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 10:36 AM
DIY Trans Bushing, Rear Shift Bush, MTEC spring Q Ralph Spoilsport Engine, Exhaust, Transmission 7 10-31-2013 10:15 PM
