Old 02-11-2014, 03:28 AM   #1
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
MTEC Shifter Spring Questions & Comments
Hey again! So I'm about to do an install for the MTEC Shifter springs on my FRS. I've seen the install video and it seems pretty straight forward but would like to see if anyone would like to share there experience with the shifter springs after install and also quick tips when installing them. Thanks!
JohnAyySays is offline   Reply With Quote
Old 02-11-2014, 04:21 AM   #2
zooki
Drives: waiting on a 2021...
Love mine. I have a Kartboy shifter also. The plugs are a pain to get out, it will take some muscle to break them loose since they have a "Loc Tite" type material on them. The driver's side was impossible to get a torque wrench on, there's not enough room between the transmission and the body to get a torque wrench in, so I just guesstimated and tightened it up. The passenger side with need a universal joint in there with an extension to get to that plug. All in all a worthwhile investment.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
Capt Spaulding (02-08-2018), jcw99 (03-04-2016)
Old 02-11-2014, 05:58 AM   #3
Malt
Drives: 2015 WRX
Its much easier with the exhaust out of the way but it can be done with it still in place. I didn't need a universal joint like mentioned to torque the plug but I did struggle with getting the passenger side threaded back in because of the excess loctite.
Get yourself some shop rags and brake cleaner if you don't have some already to clean off the loctite. Make sure you hand thread that bolt back in before you start wrenching down on it and you'll be fine.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
jcw99 (03-04-2016)
Old 02-11-2014, 07:12 AM   #4
twag4
Drives: frs
Get yourself a 10mm Allen socket and a deep well 1/2" drive break over bar with a deep well 12 point 27mm or 1 1/16" socket. It really isn't that tight, but the thread locking compound is considerable to break loose on the big fitting. Easy easy job to do if you have any experience with tools.
twag4 is offline   Reply With Quote
Old 02-11-2014, 07:15 AM   #5
jamesm
They're great. The only pita is the one big bolt near the top of the transmission. It took a breaker bar and a lot of elbow grease to get off. Aside from that the install is about as simple as it gets.
Old 08-08-2015, 12:53 PM   #6
axelo
Drives: Whiteout frs
I stripped my trans threads of the passenger side....shop say can tap without taking trans down...
axelo is offline   Reply With Quote
Old 08-08-2015, 01:41 PM   #7
s30series
Drives: 2015 BRZ Series.Blue
lol
s30series is offline   Reply With Quote
Old 08-08-2015, 02:22 PM   #8
axelo
Originally Posted by s30series View Post
lol
Youll be the first to know
Old 08-08-2015, 02:30 PM   #9
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
It helps to us a pick and scrap some of the loctite off the bolt.
TruRace is offline   Reply With Quote
Old 08-08-2015, 03:02 PM   #10
JB86'd
JB86'd's Avatar
Drives: JAWS
Clean up the bolts to get the green loctite off before reinstalling. DO NOT TIGHTEN with a wrench until you've hand threaded them and are 100% sure the bolts are lined up, or you will strip it. Get it tight and torque to the correct specs. Be patient, the big detent can be a bitch to get a wrench on, and once you do it takes some muscle to break loose.
Old 08-09-2015, 09:50 AM   #11
OkieSnuffBox
Drives: '23 BRZ Limited
Tq wrenches are for tightening, not loosening. Get a breaker bar.
Old 08-11-2015, 10:46 PM   #12
zooki
I know that. I've been wrenching on cars for 30+ years. I used the torque wrench to tighten the plug back up.
Old 08-11-2015, 11:03 PM   #13
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
that 27mm bolt was a piece of cake for me to get loose,
it took me longer to get the damn bolt up there and threaded then it did for me to loosen it
i honeslty thought the intall was super super easy, pretty straight forward
Old 08-12-2015, 02:59 AM   #14
jflogerzi
jflogerzi's Avatar
Just do it. I love how this 30$ mod makes the shifter that much better with crisper throws and some stiffness as well. No other mods are needed besides this little gem.
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 09:36 AM
DIY Trans Bushing, Rear Shift Bush, MTEC spring Q Ralph Spoilsport Engine, Exhaust, Transmission 7 10-31-2013 09:15 PM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 12:39 PM
Getting questions and good comments sweetfrs Scion FR-S / Toyota 86 GT86 General Forum 26 04-15-2013 07:03 PM
