Old 02-27-2015, 04:51 PM   #15
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
Depends on what you get. If you get a FP without a cat, then you'll be promoting (hopefully) better flow throughout your exhaust. I have the Nameless FP/OP with a High Flow Cat, and the sound, at least to me, wasn't incredibly noticeable.
Power-wise? I gained a few hp, nothing tremendous. Throttle response maybe a bit better? That I don't really know, I think I might've felt more from the lightweight crank pulley. I do remote tuning, so I'm probably not squeezing every bit out of my car, but it's something. The reason I got the FP/OP was because of my class in Autocross. I have to have a cat in my exhaust setup somewhere, so I opted for catless headers and a high flow cat in the front pipe.
Churg is offline   Reply With Quote
Old 02-27-2015, 04:53 PM   #16
Teseo
Drives: frs
I thought the resson for buy FP/OP its for prevent fitment issues,
I like to hear those members with full aftermarket exhaust
Old 02-27-2015, 07:01 PM   #17
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
This is a 2.5" flange against the stock over pipe. As you can see, not ideal for airflow.
Mad_Mike is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad_Mike For This Useful Post:
Prodigalson (09-15-2018), woode (02-27-2015)
Old 06-16-2015, 12:16 AM   #18
treymw95
Drives: 2013 scion FRS
I bought uel tomei exhaust manifold it connects to cat its not loud at all it is stock cat back is this normal If not what should I look for to fix
treymw95 is offline   Reply With Quote
Old 06-16-2015, 12:36 AM   #19
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Punctuation.
The Following 5 Users Say Thank You to Captain Snooze For This Useful Post:
BigHugeFatGuy (05-27-2022), endless_pain (01-29-2018), NWFRS (06-16-2015), swarb (06-16-2015), Ultramaroon (06-16-2015)
Old 06-16-2015, 12:51 AM   #20
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Originally Posted by zc06_kisstherain View Post
most people just buy and feel good about it. even it helps very little, we just buy it. why? because we cannot help but modding
I feel you, hugs?
Old 06-16-2015, 01:28 AM   #21
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
As far as what kind of gains you may or may not get, it depends on how all the components affect your afr. Also, a custom tune will make better, safer gains than an ofs tune; particularly with the amount of aftermarket intake and exhaust mods that you have.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 01-28-2018, 08:15 PM   #22
Jasten
So....I've had Gruppe-S headers/overpipe, stock front pipe, and Perrin 2.5 resonated catback for at least a year now and I just recently started hearing raspyness or a fine rattle that seems to be coming from the front pipe. It's mostly noticeable on cold starts and sometimes with acceleration. Just checked and there aren't any loose bolts or leaks. Could it be the cat in the front pipe gone bad? I don't know if this is relevant, it may just be me, but the exhaust smell in cabin has increased as well. I'm just wondering if anyone else has experienced anything similar.
Jasten is offline   Reply With Quote
Old 01-28-2018, 08:46 PM   #23
Impureclient
Drives: 2015 FR-S
Same header/OP and stock FP and almost exactly a year on mine and no smell or rattling.
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
Jasten (01-28-2018)
Old 01-28-2018, 08:47 PM   #24
Somerandom18
Drives: 2017 manual BRZ
I have this with the Tomei which is very similar. I have a feeling it's the slip joints vibrating ever so slightly.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Jasten (01-28-2018)
Old 01-28-2018, 09:42 PM   #25
Jasten
**I've also had a JRSC for 24,xxx mi. Low key kind of looking for a good reason to upgrade to a non-catted front pipe so it's straight all the way through, but with current funds, i'll be alright just as long as my car runs.
My train of thought is that since i'm FI, there's increased stress on that only cat left? I know that the cat can eventually get plugged resulting in my car not starting, I just don't know how fast this process takes given my situation nor do I know the symptoms associated.
Old 10-12-2019, 01:48 AM   #26
86driftcar
86driftcar's Avatar
Theres a guy in my area with a Supercharger, he dropped a K&N filter and front-pipe and went for a revision tune that gained him an extra 13+ whp... not sure if the same applies for NA engines
86driftcar is offline   Reply With Quote
Old 10-12-2019, 03:03 AM   #27
norcalpb
norcalpb's Avatar
I’d only do an aftermarket front pipe if it was a track car only. As a matter of fact I ran an aftermarket front pipe/overpipe for 3 years with my UEL and I had to apologize to multiple families about how loud my car was. It seems to add some top end power but I’d look at who your neighbors are before making such a decision.
Sometimes bigger overpipes hit the front crossmember without stiffer engine mounts.
Old 10-12-2019, 04:04 AM   #28
86MLR
86MLR's Avatar
Catless header of your choice (mine was OEM decat, cost = gaskets)
2.5" overpipe (mine was Ultrex at $90)
2.5" single or dual resonated frontpipe (mine is SME single resonated, cost $350)
OEM catback (still running it now even with boost).
With a good NA tune you should be around 200hpatw.
Cold start will still be loudish.
Once warm the car sounds nice with no drone.
Add a turbo for near OEM quietness, apart from spooling induction goodness.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Teseo (03-22-2024)
Difference between HFC and resonated front pipe? BlackyRose Engine, Exhaust, Transmission 0 09-26-2014 12:38 PM
Video Clips: Front pipe sound difference's Vmax911 Engine, Exhaust, Transmission 6 09-08-2014 07:44 PM
Does the overpipe really make a difference? Wise Engine, Exhaust, Transmission 66 03-02-2014 05:41 AM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 11:03 PM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 08:24 PM
