Drives: 2015 Subaru BRZ "Series.Blue"
Does a Front Pipe/Overpipe Really make that much of a difference???
I'm currently running the following Mods:
-Perrin CAI w/ inlet tube -OFT w/93 tune -Tomei Expreme UEL Header (catless) -Perrin 2.5" Resonated Cat back system Does adding the Overpipe/Front pipe combo really make that much more of a difference?? Is it worth the extra $$$? I've heard that the Header is really where you make most of your gains. |
| The Following User Says Thank You to UrmyboyBLUE For This Useful Post: | cameronjones239 (02-27-2015) |
Drives: Fast
Soundwise it does, but not so much performance wise on N/A. Maybe a few horsepower just due to better flow/pipe diameter increase, but negligible.
Drives: '13 BRZ
You'll likely see better gains from the front pipe than from a cat-back, but a header will give better gains than both.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | Hyper4mance2k (06-16-2015), shifter907 (02-27-2015) |
Drives: World Rally Blue BRZ
How about the overpipe alone? I have never been able to justify spending a few hundred dollars on such a small part of the exhaust.
Drives: SWP BRZ
most people just buy and feel good about it. even it helps very little, we just buy it. why? because we cannot help but modding
| The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post: | themadscientist (06-16-2015), veck (02-27-2015) |
#7 | |
Drives: SWP BRZ
so i bought Johnmotoring's overpipe. http://www.ft86club.com/forums/showthread.php?t=71763 |
#8 | |
#9 | |
Because compromise ®
Drives: Red Herring
significant and worth the money. I am not saying the increase was much but every bit helps. You are going to get different answers when asking for opinions
#10 | |
JHerbert Racing
Drives: 2013 Scion FRS
To keep with the thread topic. The only reason I am buying an over pipe is bc having just one stock piece on my exhaust would kick start my OCD to the max. I do not expect a performance gain or sound difference.
#11 |
Drives: '18 STi
People have said that replacing the stock front pipe with an aftermarket front pipe usually leads to better throttle response. I highly doubt it (because placebo effect), but it could be a possibility.
#12 | |
If/when I replace the header I'll do the front pipe, but not bothering until then.
#13 |
Pretty sure there was a well respected tuner on here that said an OP was significant gain for FI engines. Not sure about NA. Front pipe maybe not so much.
#14 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| Difference between HFC and resonated front pipe? | BlackyRose | Engine, Exhaust, Transmission | 0 | 09-26-2014 12:38 PM |
| Video Clips: Front pipe sound difference's | Vmax911 | Engine, Exhaust, Transmission | 6 | 09-08-2014 07:44 PM |
| Does the overpipe really make a difference? | Wise | Engine, Exhaust, Transmission | 66 | 03-02-2014 05:41 AM |
| What is the difference between a Front pipe, a down pipe and an over pipe? | liajet24 | Engine, Exhaust, Transmission | 5 | 09-19-2013 11:03 PM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 08:24 PM |
