Old 12-20-2016, 11:09 AM   #15
FX86
if you aren't having shifting problems then leave it alone...same with brake fluid...if your brakes work fine without having a mushy pedal feel then just leave it...others may disagree but i disagree with them too
The Following 2 Users Say Thank You to FX86 For This Useful Post:
KalbiCool88 (02-07-2017), Tcoat (12-20-2016)
Old 12-20-2016, 11:15 AM   #16
Originally Posted by N1rve View Post
60,000 miles or 60 months. It's supposed to be inspected every 30,000 miles.
I am the unofficial leader of the "Don't change your fluids just for the sake of changing your fluids" camp but the AT is one thing that does have a recommended change interval. As N1 pointed out it should be done every 60K. There is no real benefit to doing it more often unless you really beat on it or track it though.
Old 12-20-2016, 01:56 PM   #17
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Disagree provisionally...
Most transmissions have recommended change intervals and the clutch discs do wear producing particulate matter. Most also have filters that need changing.
Brake fluid - depending on the type used for your application many brake fluids have a strong affinity for moisture and will suck it out of the air leading to corrosion in the brake system.
Exceptions to every rule though - depending on application and design parameters.
nextcar is offline   Reply With Quote
Old 01-08-2017, 04:11 AM   #18
fitcious
Will dealer change it at 60k even when it says it has lifetime tranny oil?
fitcious is offline   Reply With Quote
Old 01-08-2017, 10:39 AM   #19
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I changed mine at 30,000 miles because I wanted to weld on a bung for a temp sensor. I just used Toyota fluid.
Lunatic is offline   Reply With Quote
Old 01-08-2017, 10:19 PM   #20
They will change it anytime you ask them to if you pay them.
KalbiCool88 (01-13-2017), My Key (01-20-2017)
Old 01-14-2017, 02:14 AM   #21
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It doesnt have lifetime tranny oil. It is in the manual as change at 60k. But it shouldnt matter as they will change it whenever you wish to pay them to do so
My Key (01-20-2017)
Found this while changing my tranny fluid Dipstik-sportech Engine, Exhaust, Transmission 25 12-28-2022 05:08 PM
WARNING: If you changed your transmission fluid, please read MrBodyMassage Engine, Exhaust, Transmission 47 05-09-2015 01:09 AM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 07:53 AM
part number and spec for genuine BRZ tranny fluid? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 03-28-2014 06:02 AM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 12:31 PM
