Old 05-17-2015, 07:03 AM   #15
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by HATED1 View Post
this may sound weird, but turn it in the direction to tighten it, then try to loosen it. It has worked for me in the past.
Reminds me of...
The Following User Says Thank You to Andrew025 For This Useful Post:
HATED1 (05-17-2015)
Old 05-17-2015, 12:14 PM   #16
stevesnj
stevesnj's Avatar
http://www.autozone.com/shop-and-gar...ch/344319_0_0/
My 2016 Build thread
Old 05-17-2015, 01:11 PM   #17
slim blanco
slim blanco's Avatar
Drives: 2017 86
a large channel lock plier has never failed me. i use it every time now just because it's so much easier haha.
slim blanco is offline   Reply With Quote
Old 05-21-2015, 11:18 AM   #18
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
or just man up
BlueSky is offline   Reply With Quote
The Following User Says Thank You to BlueSky For This Useful Post:
flippy (05-21-2015)
Old 05-21-2015, 12:03 PM   #19
brianhj
Drives: 2017 Camaro 1SS
Did you press the oil filter release switch while turning?
brianhj is offline   Reply With Quote
Old 05-21-2015, 12:23 PM   #20
stevesnj
stevesnj's Avatar
Good point! It's next to the blinker fluid reservoir...duh!
Old 05-21-2015, 01:12 PM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
See this post: http://www.ft86club.com/forums/showp...9&postcount=47
Old 05-21-2015, 01:53 PM   #22
cycleboy
Drives: 2013 Scion FR-S - Argento
I had to use a screwdriver and big hammer on my 2002 once. Even with every different wrench method I tried it wouldn't budge. It took about a half hour because the screwdriver could only turn about 1/8 turn each time and it made a huge mess.
In this car, it'd be easy to use a band or strap type wrench. One thing I love about this car is someone finally put an oil filter in a location where it is easy to get to and doesn't make a mess when changed. I swear every other car has them at bad angles where they spill everywhere or in tight spots so you end up bruised and bleeding and having to clean up drips in places you can't reach. My favorite is when they drip right on the exhaust and there's no way to prevent it.
cycleboy is offline   Reply With Quote
Old 05-21-2015, 04:34 PM   #23
Bergen23
Drives: '15 Halo FR-S
I have a fram oil filter wrench. Works a charm. Attaches to a ratchet, super convenient.
Bergen23 is offline   Reply With Quote
Old 05-24-2015, 10:29 PM   #24
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Fishbed77 is offline   Reply With Quote
Old 05-24-2015, 10:33 PM   #25
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
Originally Posted by stevesnj View Post
+1
iamdaspoon is offline   Reply With Quote
key keeps getting stuck Covo_86 Issues | Warranty | Recalls / TSB 14 04-21-2014 09:55 AM
O2 Sensor stuck... ThisGuy919 Engine, Exhaust, Transmission 13 10-18-2013 05:58 AM
I'm Stuck In A Dilemma ALbadboy BRZ First-Gen (2012+) — General Topics 30 02-25-2013 08:02 PM
stuck in buffalo NY FT86R Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 10:29 PM
