Engine Swaps Discussion of engine swaps. |
06-30-2014, 10:05 PM | #15 | |
Guy on internet
Drives: Slowly
06-30-2014, 11:02 PM | #16 |
Drives: 2013 FRS
Everyone forgot the part where they sell theyre old motor for 4-5k....im not sure the actual price for a used fa just through those numbers out there.
Sent from my HTCONE using Tapatalk |
06-30-2014, 11:34 PM | #17 |
Vorshlag is working on a LSx swap kit as well.
The Following User Says Thank You to xwd For This Useful Post: | Rinzler_ft86 (07-11-2017) |
07-01-2014, 01:30 AM | #18 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
More like 400-500. No one in the right mind would buy it for 4-5k lol. You can get a brand new LS3 for a grand more, or you can get some other stronger import engine for a fraction of that.
07-01-2014, 01:49 AM | #19 | |
Drives: 2013 FRS
http://m.ebay.com/itm/331237413584?nav=SEARCH Sent from my HTCONE using Tapatalk |
07-01-2014, 10:29 AM | #20 |
Drives: Car
No reason NOT to buy an aluminum LS3. If you can't afford an LS3...you probably shouldn't be doing a V8 swap.
07-01-2014, 01:07 PM | #21 |
Drives: 2JZ FRS
from someone who spent the last 6 months helping someone do an ls2/t56 swap in an frs, i bought a built fa20 short block and a bigger turbo setup to replace my current setup. there are still issues to be sorted out with the swap. it has not been very fun. even with a stock ls2 i am still way below the cost of the swap
The Following User Says Thank You to spitfire481 For This Useful Post: | hmong337 (02-01-2015) |
07-01-2014, 02:49 PM | #22 | |
07-01-2014, 02:52 PM | #23 | |
07-01-2014, 03:01 PM | #24 | |
Drives: 2JZ FRS
the built fa20 plus turbo kit is less than a two day install plus tuning and its good to go. |
07-01-2014, 03:02 PM | #25 |
I Love custom Turbo kits
Drives: Limited BRZ
So what turbo kit are you using now?
07-01-2014, 03:07 PM | #26 | |
What were the problems mostly? Electrical, ecu, chassis wiring, brakes/abs, steering electronics, clutch, gas pedal/throttle position, etc? ..or prolly just a little bit of everything? lol |
07-01-2014, 03:08 PM | #27 |
Drives: 2JZ FRS
there are things "in the works". a motor is being built at full blown, and the kit is going to be ordered before the weekend its looking like. i dont trust the stock wrist pin setup. it seems to be a timebomb in my opinion. i dont want to risk loosing a $3k core charge motor because i pushed my luck too long.
going to be a 10:1 build block. full blown kit with a 5858 more than likely. i have went through days of considering upgrading the avo 18g to a 20g, 60-1 wheel, even a gtx2867r if i could make it fit. for the pricing im getting its worth it to just swap and sell my setup at this point. i made 400whp on it, its well maxed out and has done its original job. the car is fast, way fast. but there is always more and with this block id like to be around 475whp on e85. the added lag should help me hook up better. its a struggle now with boost at 3k rpm's. even on hot, 20psi 255 nt05's |
The Following User Says Thank You to spitfire481 For This Useful Post: | Sportsguy83 (07-01-2014) |
07-01-2014, 04:27 PM | #28 |
Drives: 2013 Subaru BRZ
I researched this swap extensively and found that the hardest part is telling your parents you're gay. I don't think I could pull that off, so I gave up on the idea.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Hard choices | pearsor1 | BRZ First-Gen (2012+) -- General Topics | 24 | 02-24-2014 07:41 PM |
How hard is it really? | Kimsey47 | Issues | Warranty | Recalls / TSB | 13 | 08-16-2013 11:01 PM |
Was I being hard on my car? | Fr-s13 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 07-04-2013 09:54 PM |
The hard part is done! | koteman | Other Vehicles & General Automotive Discussions | 27 | 10-11-2012 01:02 PM |
