Old 06-30-2014, 10:05 PM   #15
pche
Guy on internet
Drives: Slowly
Originally Posted by fooddude View Post
With a nice bolt on kit with all the needed accessories (cooling, ac/heater, fuel, wiring/electrical, headers, exh, driveshaft, making steering linkage and abs compatible if needed, ecu, etc) needed ($8k), LS3 crate engine ($6k), brand new tranny that fits perfectly (Magnum XL) with clutch and flywheel ($4k)....$18k for a brand new engine/tranny setup..give or take a few thousand for anything missing or the unexpected that may come up..so round up maybe an extra $2k..giving you $20k for all parts. Labor, do it yourself (which should be pretty easy since it's bolt-on and no welding/fabbing or engine block/tranny rebuilding experience needed)..or have a shop do it for $5k.
So for a proper, super nice and clean, brand new swap...$20k DiY ...or $25k if a shop does it.
Imo, and for the budget conscious, it is def not worth it to do it to a relatively new FRS/BRZ (it would be $28k for the car and $25k for the swap...bringing you to the same cost as a brand new corvette at $53k and other great cars in that range...not to mention, those cars will be made for the LS(or whatever else engine it came with) in terms of stronger chassis, bigger wheels/tires with suspension specifically made for that chassis and powerful engine) ....but totally worth it down the road instead of buying a new car. Maybe do it 5-15 years down the road, when the FA engine gets old, past 100k miles and/or blows up.
Finally, someone with some sense.....all that money you can get a way better car with a warranty. You'll be driving it and enjoying it instead of sweating over every weird little noise you hear.
pche is offline   Reply With Quote
Old 06-30-2014, 11:02 PM   #16
ft86xtc
Drives: 2013 FRS
Everyone forgot the part where they sell theyre old motor for 4-5k....im not sure the actual price for a used fa just through those numbers out there.
Sent from my HTCONE using Tapatalk
ft86xtc is offline   Reply With Quote
Old 06-30-2014, 11:34 PM   #17
xwd
Vorshlag is working on a LSx swap kit as well.
The Following User Says Thank You to xwd For This Useful Post:
Rinzler_ft86 (07-11-2017)
Old 07-01-2014, 01:30 AM   #18
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
More like 400-500. No one in the right mind would buy it for 4-5k lol. You can get a brand new LS3 for a grand more, or you can get some other stronger import engine for a fraction of that.
fooddude is offline   Reply With Quote
Old 07-01-2014, 01:49 AM   #19
ft86xtc
Drives: 2013 FRS
just going off ebay here, 26k miles and no tranny for 3400
http://m.ebay.com/itm/331237413584?nav=SEARCH
Old 07-01-2014, 10:29 AM   #20
JasperNoone
Drives: Car
No reason NOT to buy an aluminum LS3. If you can't afford an LS3...you probably shouldn't be doing a V8 swap.
JasperNoone is offline   Reply With Quote
Old 07-01-2014, 01:07 PM   #21
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
from someone who spent the last 6 months helping someone do an ls2/t56 swap in an frs, i bought a built fa20 short block and a bigger turbo setup to replace my current setup. there are still issues to be sorted out with the swap. it has not been very fun. even with a stock ls2 i am still way below the cost of the swap
The Following User Says Thank You to spitfire481 For This Useful Post:
hmong337 (02-01-2015)
Old 07-01-2014, 02:49 PM   #22
fooddude
Ah, I see..I stand corrected then. But, I still think it'll be hard and a long time to sell it, as they aren't exactly hot sellers.
Old 07-01-2014, 02:52 PM   #23
fooddude
Sorry, misunderstood your wording/post..What are you trying to say? ...so you're saying the FA Turbo swap was the one that was more of a headache and not very fun, correct?
Old 07-01-2014, 03:01 PM   #24
spitfire481
Drives: 2JZ FRS
sorry. no, the ls2 swap has been a never ending headache trying to get everything to work properly. i originally thought about a swap but i really dont want to deal with the time/money/headache that he has went through for my own car. a bare bones swap, sure, not terrible. still a lot of issues with fitment, cooling, wiring, etc. but doing a swap that still keeps ac, both ecu's, power steering, stock cluster, etc. ill pass
the built fa20 plus turbo kit is less than a two day install plus tuning and its good to go.
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
flippy (01-30-2015), fooddude (07-01-2014), hmong337 (02-01-2015)
Old 07-01-2014, 03:02 PM   #25
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So what turbo kit are you using now?
Old 07-01-2014, 03:07 PM   #26
fooddude
Ahh..I see. That does sound like a pain (especially when not many have done it yet).
What were the problems mostly? Electrical, ecu, chassis wiring, brakes/abs, steering electronics, clutch, gas pedal/throttle position, etc? ..or prolly just a little bit of everything? lol
Old 07-01-2014, 03:08 PM   #27
spitfire481
Drives: 2JZ FRS
there are things "in the works". a motor is being built at full blown, and the kit is going to be ordered before the weekend its looking like. i dont trust the stock wrist pin setup. it seems to be a timebomb in my opinion. i dont want to risk loosing a $3k core charge motor because i pushed my luck too long.
going to be a 10:1 build block. full blown kit with a 5858 more than likely. i have went through days of considering upgrading the avo 18g to a 20g, 60-1 wheel, even a gtx2867r if i could make it fit. for the pricing im getting its worth it to just swap and sell my setup at this point. i made 400whp on it, its well maxed out and has done its original job. the car is fast, way fast. but there is always more and with this block id like to be around 475whp on e85. the added lag should help me hook up better. its a struggle now with boost at 3k rpm's. even on hot, 20psi 255 nt05's
Sportsguy83 (07-01-2014)
Old 07-01-2014, 04:27 PM   #28
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
I researched this swap extensively and found that the hardest part is telling your parents you're gay. I don't think I could pull that off, so I gave up on the idea.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Hard choices pearsor1 BRZ First-Gen (2012+) — General Topics 24 02-24-2014 07:41 PM
How hard is it really? Kimsey47 Issues | Warranty | Recalls / TSB 13 08-16-2013 11:01 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
The hard part is done! koteman Other Vehicles & General Automotive Discussions 27 10-11-2012 01:02 PM
