Old 06-18-2014, 01:30 PM   #15
Mikem53
Drives: FR-S 6MT
Originally Posted by Astroboy View Post
ok look, so look I'm in my car, I turn the steering wheel completely to the right in a complete stop, I turn on the ignition and I hear a pop coming from the right. at start. the car also starts shaking very violently from that side.
Sent from my LG-D800 using Tapatalk
Clear as mud.
Mikem53 is offline   Reply With Quote
Old 06-18-2014, 03:42 PM   #16
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Reaper View Post
Sounds like di seals.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
it's only when the steering wheel is turned completely to the right though.. when I turn it on and it's straight, no noise. when I'm on a slope, noise
Astroboy is offline   Reply With Quote
Old 06-18-2014, 03:46 PM   #17
Astroboy
Astroboy's Avatar
Drives: None
plus the revs don't change... no back fire.
Old 06-18-2014, 03:47 PM   #18
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by kiichiro View Post
Don't count on it being injectors. Lots of things make pop sounds in the exhuast
not the exhaust
Old 06-18-2014, 06:03 PM   #19
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Mikem53 View Post
do you get the popping noises after its warmed up?
not uncommon to hear a pop or feel a "miss" when cold, but should not occur after warmup.
After it's warmed up...
Old 06-18-2014, 06:05 PM   #20
Astroboy
Astroboy's Avatar
Drives: None
I tried it again and after I drive it for a while, it starts to pop...
Old 06-18-2014, 06:55 PM   #21
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Then it would seem pretty obvious that the injector have nothings to do with it!
The "shaking" probably is because you are at the steering limit and are overloading/stalling the PS.
There seems to be a simple solution...don't crank the steering wheel full right before starting the engine.
billwot is offline   Reply With Quote
Old 06-22-2014, 09:26 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
It happens even when a start it normal and drive it for about an hour or so
Old 06-22-2014, 09:55 PM   #23
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
I would take the car to a mechanic rather than just randomly replacing things. It sounds like you are throwing parts at the problem.
Quentin is offline   Reply With Quote
The Following User Says Thank You to Quentin For This Useful Post:
OICU812 (06-23-2014)
Old 06-22-2014, 10:02 PM   #24
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Take it back to the tuner that put your Turbo In and have them check your Muffler Bearings. I'll bet #3 is blown...
ntron1 is offline   Reply With Quote
The Following 2 Users Say Thank You to ntron1 For This Useful Post:
Basket Case (06-23-2014), OICU812 (06-23-2014)
Old 06-23-2014, 01:15 AM   #25
whataboutbob
AutoX-10/10ths every run
It would be a good idea to check your DI seals. If they are bad and you continue to drive the car you'll probably be paying for motor work soon. I just recently had the popping issues with my car and tore into the DI injectors and replaced all of the seals. I've been FI'd for 20K+ with lots of Autox days.
Build thread:Here
Old 06-23-2014, 08:45 PM   #26
Astroboy
Astroboy's Avatar
Drives: None
were your seals bad?
Old 06-23-2014, 08:53 PM   #27
Astroboy
Astroboy's Avatar
Drives: None
also any check engine lights?
Old 06-23-2014, 08:59 PM   #28
whataboutbob
They weren't bad, but they were pretty well cooked. I also had a P0302 show up but it didn't keep the CEL illuminated.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Astroboy (06-23-2014)
Does the USB port charge your phone? EAGLE5 Electronics | Audio | NAV | Infotainment 30 08-15-2014 01:44 AM
Labor time to replace pump and injectors? misooscar Forced Induction 4 06-10-2014 10:37 AM
Do you feel in Charge? LS13 Off-Topic Lounge [WARNING: NO POLITICS] 0 03-28-2014 09:01 PM
Dealership is charging me $1725 to replace my OEM clutch for BR-Z venom8776 BRZ First-Gen (2012+) — General Topics 147 02-02-2014 08:34 AM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
