#15 | |
Drives: Toyota 86
With the AC on in traffic, the fan is always on and will keep coolant temps below 95C. |
#16 |
If the car was getting hot enough that it turned off the AC to prevent it from overheating you would most definitely notice the temp gauge running way too high.
Plus, it's not THAT hot in Canada yet, so it really shouldn't be having heat issues. I've had days where in BAD traffic the AC isn't as cold as it normally is, but it's still cold. I've never had it turn right off, or had the temps creep up (based on the gauge, not by accurate logging) either.
| The Following User Says Thank You to wparsons For This Useful Post: | Minovsky (05-10-2014) |
#17 | |
Drives: 2013 asphalt scion FRS
Can you explain to me how the AC pushes heat into the radiator, since you know...it's not connected in any way. You almost had one part right though, AC is a setup of heat exchangers, NOT heat pumps. The condenser is what takes the heat, NOT the radiator. It then goes to the evaporator which once again, reduces heat. The ONLY part of the hvac system to deal with the radiator is the, heater. As for the idle issue, you all do know there is a tsb out for that right?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
| The Following User Says Thank You to J_kennington For This Useful Post: | HRTROB (05-10-2014) |
#18 |
Drives: Toyota 86 TRD Version AT
If the ac blew warm air while the idle became erratic, that is a clue. It's either the ac system could not handle the heat and the pressure in the ac system shot up. This usually causes the compressor to stop because you cannot add more pressure, thus stopping the freon from circulating.
This scenario usually happens when the coolant temps cannot handle the heat and the cooling system simply overheats. This happens a lot in Manila because of the heat and bad traffic. Things to check for are: Radiator coolant level Radiator cap might be leaking Radiator fans might not be turning on that's why it happens during traffic AC system might have sprung a leak and caused a vacuum leak which made the idle erratic
| The Following User Says Thank You to Tye300 For This Useful Post: | Minovsky (05-10-2014) |
#19 | |||
Drives: 2013 GBS BRZ Limited
In the refrigeration cycle, a heat pump transfers heat from a lower-tempeature heat source (the evaporator in the passenger compartment) through the compressor (which makes the refrigerant HOT as it is compressed back to liquid) then it dumps that heat into a higher-temperature heat sink (The AC radiator). The AC radiator IS ATTACHED TO THE ENGINE RADIATOR. In SOME cars the AC radiator is INSIDE the engine radiator. By running the AC you are dumping heat directly into the radiator. This is especially hard on the system when there is less air flow through the two radiators than when the car is moving. When you argue with an engineer you make yourself look stupid. |
#20 | |
Drives: Fr-s 2013 white out
#21 | |
I was just pointing out that the ECU software cycles the AC compressor on and off for various reasons. One can be for economy - No reason to run the AC at 100% duty cycle if the demand is only 20%. So it turns the AC compressor on and off via the solenoid clutch in the AC compressor. The software can just decide to give less and less drive to the AC pump as it detects engine temps rise. I thought I even heard of someone comment that their AC would not work after driving the car at the track hard because the engine temps were too high... |
#22 | |
#23 |
#24 |
Drives: waiting on a 2021...
Most(if not all) car manafacturers spend a lot of time and money making sure their cars will not overheat on hot days. If you've ever seen pictures of the "heat soak" buildings a lot of them have in Arizona you'll know that they leave their automobiles sitting in them, running, with all the accessories on for hours and hours. I find it really hard to believe Toyota skipped this step in testing. I would have to say its something else, and NOT normal.
As far as arguing with engineers, I've worked in the petrochemical industry for 20+ years, and can assure you engineers CAN and ARE wrong quite a bit. We in the operations side of things just love it when we get brand new engineers at work...it seems that some of them trade in their common sense for that sheepskin to hang on their wall....
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#25 | |
#26 |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
we are all dumber for reading this nonsense...
#27 | |||
And note: You never said Oops I am sorry I was wrong. Quote:
I can say for a fact: You are wrong. Running the AC DOES make your engine run hotter. Period. One of the things I do for a living is instrumented thermal testing of systems far more complex than a car. SO even your "Even when they have nothing to do with engineering the system in question." is incorrect. You said that an air conditioner was not a heat pump, it was a heat exchanger. You were wrong. And it is 100% a fact that the running the AC adds heat to the engine's cooling system. You dont need to be an engineer to understand this. AND I never said that the OPs car was overheating or WAS going to overheat. I merely stated that as the car sits in traffic with the AC running that the software will begin to do things to keep the car cool. Such as turning on the electric fans and cycling the AC compressor more frequently. I honestly have no idea why you even argued with that statement as it is fact. And being an old fart we were always taught to not run the AC unless the car is moving. I guess young kids these days think cars have always been perfect and have had computers in them to manage themselves. Quote:
FACT: Running the AC dumps a huge amount of heat into the car's cooling system. FACT: Running the AC adds a significant load to the engine. FACT: The car gets less cooling when not moving. Now you can debate whether it's bad for the car or not all you want, but the above are facts. Or are they NOT facts just because I am an engineer and engineers are always wrong? |
| The Following User Says Thank You to stugray For This Useful Post: | Minovsky (05-13-2014) |
#28 |
I didn't say you were always wrong, what I said was car manafacturers spend a lot of time testing for things like this. I guess I took exception to the line "When you argue with an engineer you make yourself look stupid". Kinda condescending, no? I've argued with a few, and I've been right. I've been wrong also, but it's not a given.
There has to be something else wrong with the car otherwise every one of these cars would exhibit this behavior in hot climates. I myself live in south Texas and last summer we had many 100+ degree days and my car never exhibited any of these symptoms. So is my car the exception, or the OP's?
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: Last edited by zooki; 05-11-2014 at 05:36 PM. |
| The Following User Says Thank You to zooki For This Useful Post: | stugray (05-11-2014) |
| Really weird problem: Have to fill with fuel very slowly | Kido1986 | Issues | Warranty | Recalls / TSB | 31 | 08-20-2017 12:11 PM |
| Won't go into first when hot and in traffic | mrha | BRZ First-Gen (2012+) — General Topics | 39 | 06-01-2017 03:15 PM |
| Traffic Tickets Anyone? | SocalBurt | Scion FR-S / Toyota 86 GT86 General Forum | 325 | 04-18-2016 07:51 AM |
| Dangerfield is in the traffic | newft86 | AUSTRALIA | 12 | 06-25-2012 09:57 PM |
| Traffic Nav Not working on my BRZ | Indestruct | Electronics | Audio | NAV | Infotainment | 9 | 06-19-2012 10:38 PM |
