Old 04-04-2019, 11:45 PM   #15
humfrz
mmmm, milkshakes for everyone!!
That will be oil trying to drain out of @Tcoat 's car's transmission, if he ever decides to change it -
humfrz
Old 04-04-2019, 11:48 PM   #16
humfrz
Why does it hurt when I pee?
Most likely caused by an out of balance mix of antibiotics -
humfrz
Old 04-05-2019, 12:31 AM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Those rarely end well.
Most certainly.
Old 04-05-2019, 12:38 AM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
humfrz
My first thought was me after some street taco's, but i was trying to avoid the imagery. Oh well.
Old 04-05-2019, 12:42 AM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I had a catastrophic oil cooler failure in my old 911 while racing. Rear oil cooler on the front of the engine split open. Luckily it all blew on the motor making an instant major cloud, giant red light went off on the dash, and I got it shut down with no damage. Tower it home and dropped the powertrain again. Just sharing.
Old 04-05-2019, 01:10 AM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
About 20k miles on a Mocal 19-row cooler kit from MAP Performance. I've never gotten hot oil since, and the car ran great in track days. No leaks from the system either, at least not once I got a proper-sized wrench.
https://www.maperformance.com/produc...-jdl-oilcooler
Old 04-05-2019, 02:42 AM   #21
toyfighter
Drives: almost stock brz 2012 made
Cold oil pressure easily surpasses 125 PSI. Heat and pressure cycles will find the weak spot. An oil cooler is a terrible place to cheap out.
I'm using this for about a year and nothing happened, not recommending, just telling
toyfighter is offline   Reply With Quote
Old 04-05-2019, 02:53 AM   #22
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'm sure it's fine. Expensive ones fail too. Just less often, we hope.
Old 04-08-2019, 03:10 AM   #23
toyfighter
cheap or expansive, both will not survive after hitting the wall)
Old 04-08-2019, 09:34 AM   #24
Tokay444
Anti stance.
Tokay444's Avatar
Cheap. Reliability. Performance.
Pick two.
Old 04-08-2019, 01:00 PM   #25
Grady
Grady's Avatar
If the cooler was larger than the wall it could survive!
Old 04-12-2019, 03:44 PM   #26
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
I ran a rev 9 ebay cooler with mocal sandwich plate for 9 months (20k miles) with my sbd turbo kit. it never leaked. the temps stayed under 220 on highway pulls. i never tracked it so i cant say how it wouldve held up to constant high temps. if all your doing is daily driving, with occasional spirited runs you dont always need $700 racecar parts despite popular belief. the kit in total cost me $220.
glorydays is offline   Reply With Quote
Old 04-12-2019, 06:04 PM   #27
new2subaru
Weight Weenie
Drives: 15 FR-S
9 months is not a test or a long time.
The first thing I did was put some shitty pulleys on my car. They chewed up a belt and the bearings failed in every single one. This was in 3,000km. Never again.
Research, buy the best you can or don't do it at all is my opinion now.
Old 05-04-2019, 08:20 PM   #28
jflogerzi
jflogerzi's Avatar
Don't cheap out when it comes to an oil cooler. Stick with proven companies.
2013 Series 10 FRS #553
Oil coolers that will fit with the TRD intake? Hanakuso Engine, Exhaust, Transmission 28 03-05-2022 11:24 AM
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
Oil coolers price range mike_ekim1024 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 12-24-2013 02:04 AM
those with perrin oil coolers bkblitzed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 12-08-2013 12:34 AM
HKS Oil Coolers in stock Sam Strano Engine, Exhaust, Bolt-Ons 3 11-13-2012 01:41 PM
