Old 11-24-2013, 03:43 AM   #1
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
those with perrin oil coolers
How much oil are you putting in after draining it? 6 or 7 quarts?
bkblitzed is offline   Reply With Quote
Old 11-24-2013, 09:05 AM   #2
Philly758
Drives: GMC
I don't have one, but the install instructions say you will need an additional quart.
http://perrinperformance.com/attachment/74777-.pdf
Philly758 is offline   Reply With Quote
Old 11-24-2013, 01:03 PM   #3
brillo
Drives: 2013 Firestorm FR-S
My setup which is custom but effectively the same cooler needed about an additional quart.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 11-24-2013, 01:26 PM   #4
bkblitzed
is better than you
bkblitzed's Avatar
I fill my car with 5 quarts instead of what the owners manual suggests which is like 5.5 or something. So I'm guessing 6 quarts with be enough right?
Old 11-26-2013, 01:24 PM   #5
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
The oil in the cooler will not drain when you drain your oil. Just put in the normal 5ish quarts it takes when doing your oil changes.
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
PERRIN_Chris (11-26-2013)
Old 11-26-2013, 02:49 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This.
Old 11-26-2013, 03:42 PM   #7
F1point4
Photo Specialist
F1point4's Avatar
Originally Posted by Marchy View Post
is there a concern that you have 5k mile old oil in the oil cooler?
The stock motor takes around 5.5qt on a fillup, people say to add another 1qt for an oil cooler.
so 1 out total 6.5qt is only 15% of the total oil. As you keep changing your oil, this 15% will blend in with the new oil, then some of it will get drained out on the next change. Practically speaking, the oil left over on the next change will be less than 15% the oil from the first run.
Overall, I change my oil so much (every 3-4k miles or after a track event) that I will eventually dilute the "old" oil out so it won't harm my motor.
We have to remember, tHere are people in this world who drive their cars and never change the oil and do this for tens of thousands of miles before having major issues.
Marchy (11-26-2013)
Old 11-26-2013, 04:21 PM   #8
bkblitzed
is better than you
bkblitzed's Avatar
thanks, was wondering about the oil in the cooler and how i would get that out. So even with the oil cooler you're only putting 5 quarts?
Old 11-26-2013, 06:01 PM   #9
brillo
my stock RX8 has dual oil coolers and I had 8 years and 80K miles on it with the engine going strong and I never once worried about the "old" oil that didn't get changed when I did my typical oil change.
Given we are running synthetic oil stock, and your cooling the oil with the cooler, your overall oil mix will be just fine.
Old 12-08-2013, 12:34 AM   #10
ft86me
ft86me's Avatar
Drives: 2013 FRS
7 quarts on my frs with the perrin oil cooler
ft86me is offline   Reply With Quote
Oil coolers that will fit with the TRD intake? Hanakuso Engine, Exhaust, Transmission 28 03-05-2022 11:24 AM
FS: (SOLD) Perrin Crank Pulley / AEM Intake / OEM Filters (Price Drop!!!) kvnchu Engine, Exhaust, Bolt-Ons 35 02-09-2014 05:44 PM
New Twist On Oil Coolers @ Pure Automotive Performance Pure Automotive Engine, Exhaust, Transmission 39 04-09-2013 10:33 PM
HKS Oil Coolers in stock Sam Strano Engine, Exhaust, Bolt-Ons 3 11-13-2012 01:41 PM
