#15 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
So to confirm, if you hold the clutch and the gas pedal to the floor and press the start button the BRZ limited.. It will turn over until you press the button again. It may turn off if you let the clutch go as well, but I just pressed the button to stop it. Last edited by Ranatsu; 03-19-2014 at 05:15 PM. |
#16 | |
Drives: 2005 Toyota Camry
The key here is, with the right grade of oil you shouldn't need to worry about oil temps once coolant hits the proper temperature range. That usually is around 80C on coolant. -alex |
| Time attack roll cage question | Thongpocket | Tracking / Autocross / HPDE / Drifting | 4 | 02-07-2014 12:27 PM |
| Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 07:18 AM |
| startup behaviour | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 01-30-2014 09:07 PM |
| long startup!!! HELP! | juanam0909 | Issues | Warranty | Recalls / TSB | 11 | 05-18-2013 08:17 PM |
| eng warming up | foxhu | Issues | Warranty | Recalls / TSB | 8 | 05-08-2013 12:07 AM |
