Old 01-30-2014, 08:13 PM   #1
notout86
Drives: GTS 86 auto
startup behaviour
  • Now and again (once a month over 9 months ) I have had the car start then stop right away. Hot or cold no difference. I may need 3 attempts
    The other day it started, then died, then seemingly restarted itself without pressing the button but I did still have my foot on the brake. I'm not sure
    whether I usually come off the brake at once.
    Re-reading the Manual it suggests that this may be normal and that you should keep on the brake until it is fully started. It also says (a few pages over)
    that you do not have to keep the button pressed until fully started.
    Before I tackle Toyota can others enlighten?
notout86 is offline   Reply With Quote
Old 01-30-2014, 09:07 PM   #2
dnieves
Drives: FR-S 10 Series
I just hold down the clutch, press start (it starts within a second) let off on the clutch and it stays on. Been like this in 10F to 90F degree weather.
dnieves is offline   Reply With Quote
Transmission noise at startup Toxicmilk45 Issues | Warranty | Recalls / TSB 2 01-28-2014 11:03 AM
Normal engine startup? NWFRS Engine, Exhaust, Transmission 16 10-18-2013 03:17 AM
long startup!!! HELP! juanam0909 Issues | Warranty | Recalls / TSB 11 05-18-2013 08:17 PM
NAV startup screen brett_g Electronics | Audio | NAV | Infotainment 1 07-22-2012 07:16 AM
Help finding thread about startup rpm needle Prava Electronics | Audio | NAV | Infotainment 2 07-01-2012 01:29 PM
