Old 02-07-2014, 11:25 AM   #1
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Time attack roll cage question
I was wondering if anybody could tell me quickly if the time attack events such as the one at Road Atlanta on May 9th and 10th allow harness bars or if you need to have a cage? And if a cage is needed, Can it be bolted in or must it be welded in? Thanks for the replies I'm at work and wasn't able to look to the rule book.
Sent from my XT1080 using Tapatalk
Thongpocket is offline   Reply With Quote
Old 02-07-2014, 11:39 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I know in NASA Time Trial events you aren't required to have any safety equipment installed. All you need is a time trial license and a transponder.
It looks like the event you mentioned is a Global Time Attack event:
http://www.globaltimeattack.com/even...formula-drift/
Here are the rules and a tech sheet:
http://www.globaltimeattack.com/wp-c...2014-Rules.pdf
http://www.globaltimeattack.com/wp-c...afety-Tech.pdf
To answer your question:
1. A 6-*‐point roll cage is strongly recommended for all classes and is required in the Unlimited Class meeting GTA CCR Section 4 specs.
Old 02-07-2014, 11:45 AM   #3
It depends purely on the organization. You don't need one for GTA.
Old 02-07-2014, 11:50 AM   #4
Thongpocket
Master Troll
Thank you very much. I may just do a harness bar then as I like to be snug in my seat when I race. So far i've only done autocross tho.
Old 02-07-2014, 12:27 PM   #5
Don't use a harness bar unless you have at least a roll bar, HANS (or equivalent), and a bucket seat.
If you have just a harness bar, you're going to be very sorry if you ever get into ANY wreck.
Safety systems are to be used as a system; you can't just pick and choose what's convenient for you. You'll be injured worse with just a harness bar and harnesses.
Stick to the OEM 3 point, and use a CG-lock if you want to stay snug.
Roll cage for a DD? Yamajee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-10-2018 10:27 PM
Roll cage (Stealth Inc.) Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 12-16-2013 11:51 AM
OptionJDM - Cusco Roll Cage OptionJDM Interior Parts (Incl. Lighting) 3 07-18-2012 11:22 AM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 03:51 PM
Ae86 roll cage in initial d? CyberFormula Off-Topic Lounge [WARNING: NO POLITICS] 8 03-13-2010 11:23 PM
