Old 05-05-2013, 08:43 PM   #1
juanam0909
Drives: scion fr-s
long startup!!! HELP!
Guys today when i started my car it took me a second try to start the car, the first one i turned the key and wouldnt start then the second try it started right away. it happened twice today. im in tx and is about 75 degrees. help please
juanam0909 is offline   Reply With Quote
Old 05-05-2013, 08:44 PM   #2
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Pump Fuel?
All stock?
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 05-05-2013, 08:57 PM   #3
juanam0909
Drives: scion fr-s
yes all stock
Old 05-05-2013, 09:43 PM   #4
ahausheer
Re-member
Drives: Toyota camry
You may want to read about an issue with the injectors, http://www.ft86club.com/forums/showthread.php?t=20930
Could be completely unrelated, but figured id point it out. Also, make sure the battery has enough juice.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 05-05-2013, 11:20 PM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
Cold weather? Mine needed a second crank when it was cold.
mashal is offline   Reply With Quote
Old 05-06-2013, 08:57 PM   #6
juanam0909
Drives: scion fr-s
guys i realized i was turning the key too fast and not letting the ignition start right. if that makes sence for yall....
Old 05-16-2013, 08:24 AM   #7
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Try to allow the ignition on acc just before you try to turn it over for about 10sec. Thus allows the ECU to gather its data for engine management . Remember the starter is the biggest load and draws over 100 amps.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 05-16-2013, 08:39 AM   #8
Mikem53
Drives: FR-S 6MT
You should turn the car to ignition, just one click shy before starting.. Just for a second or two then start it.. This turns on the fuel pump and pressurizes the fuel system.
Mikem53 is offline   Reply With Quote
Old 05-16-2013, 10:24 AM   #9
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Sit in the car, turn key to ACC, put on seatbelt, start car. Its a good way to give the car time to do its start up check.
Freetime is offline   Reply With Quote
Old 05-17-2013, 07:18 PM   #10
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
the only time i had that happen was when i immediately tried to start the car upon entering. now, i just wait until it stops beeping before i start it.
shiumai is offline   Reply With Quote
Old 05-17-2013, 08:21 PM   #11
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
Yep, pretty much what everyone else above has said. I had the same issue, so I started to be more patient, turning the key to ACC and letting the gauges come to life, before starting the engine. In fact, I even set my RPM limit at 7400 JUST so i can watch and wait for the tach sweep before I start the car.
EK_Golfer is offline   Reply With Quote
Old 05-18-2013, 08:17 PM   #12
wbsrazzle
Drives: Subaru BRZ 6MT LTD
This has happened to me once or twice. I have the limited BRZ. I immediately start the engine when I plop down in the seat, and have no problems since. I would not worry about it unless it becomes a regular occurrence.
wbsrazzle is offline   Reply With Quote
Show your custom Navigation startup picture! LeeMaster BRZ Photos, Videos, Wallpapers, Gallery Forum 24 11-14-2013 03:44 PM
Strange engine noise during startup (Video inside) StOpNG0x Issues | Warranty | Recalls / TSB 2 01-29-2013 07:24 AM
NAV startup screen brett_g Electronics | Audio | NAV | Infotainment 1 07-22-2012 07:16 AM
Help finding thread about startup rpm needle Prava Electronics | Audio | NAV | Infotainment 2 07-01-2012 01:29 PM
2013 FR-S (Auto) Cluster Startup Sequence xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 05-21-2012 06:36 PM
