Old 11-19-2013, 06:21 PM   #15
brillo
Drives: 2013 Firestorm FR-S
I highly doubt it was your oil. I would check things like tire pressure, your air filter and other items that could cause a drop in mileage. In addition, winter blend fuels will give you different mileages that summer blends and I bet your area has recently switched over.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 11-19-2013, 06:40 PM   #16
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by IceFyre13th View Post
But to answer more, Google this < Mobil 1 and boxer engines > you will find that most people say stay away from Mobil 1 for boxer engine use
Someone should tell the engineers at Porsche that they're using the wrong oil for every boxer engine they've made since 1996 then...
(Specifically, Mobil 1 0W-40, if I remember right)
chrisl is offline   Reply With Quote
Old 11-19-2013, 07:47 PM   #17
roddy
roddy's Avatar
Drives: '13 Ultramarine
TGMO full synthetic 0W20 from your local Toyota dealer is very good oil, and made by the same folks who make Mobil 1. The price is decent as well.
Old 11-19-2013, 07:51 PM   #18
Muskokan
Drives: white Sport-tech
Oh no I used mobile 1!!! Faaack
Atleast I didn't lose fuel economy!
Muskokan is offline   Reply With Quote
Old 11-19-2013, 07:58 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
There is absolutely nothing wrong with your oil, assuming you got the same 0W-20 grade as factory fill.
Like what someone else has said, something else is contributing to your fuel consumption increase.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
rice_classic (11-19-2013)
Old 11-19-2013, 10:59 PM   #20
sirsol66
Drives: 2013 FRS- Hot Lava
Are you sure its not the changing blends of gasoline for winter? I had the same change from oem fill to Amsoil, saw the same drop in gas mileage, but I attributed it to different gas rather than the amsoil.
sirsol66 is offline   Reply With Quote
Old 11-19-2013, 11:15 PM   #21
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Originally Posted by White0utFrs View Post
Thanks! You use the one with the green front right? Notice anything different from the engine with it?
No differences that I have noticed. Still runs as smooth as it did from day 1. Gas mileage seems unchanged, maybe even a touch better.
FReSh is offline   Reply With Quote
Old 11-19-2013, 11:31 PM   #22
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
That's strange I've used Amsoil on every vehicle I've owned for the last 25 years now and no issues and have always gotten better mpg. Most often it's been used on High Performance VW Beetles where only thing protecting them has been the oil.
Sorry to hear that.
I do plan to use Amsoil in my FR-S of course the recommended weight
subwaynm is offline   Reply With Quote
The Following User Says Thank You to subwaynm For This Useful Post:
Chad86 (11-08-2015)
Old 11-20-2013, 12:25 AM   #23
White0utFrs
White0utFrs's Avatar
Drives: 2013 Scion FR-S White Out
Man these oil threads always go in an interesting direction. Thanks for all the input peeps!
I'm going to give the oil some more time and check other things. Might just be me getting comfortable with the car, and I'm not babying it anymore.
White0utFrs is offline   Reply With Quote
Old 11-20-2013, 12:37 AM   #24
humfrz
.............. Might just be me getting comfortable with the car, and I'm not babying it anymore......
....and THAT just might be a big BINGO .......
humfrz
subwaynm (11-21-2013)
Old 11-20-2013, 12:40 AM   #25
White0utFrs
humfrz
Hahahaha!
Old 11-20-2013, 02:40 PM   #26
autobrz
Drives: Mazda 3
related question: where do you order your amsoil product? Is there a place for a good discount? Also, does amsoil make a good gear oil for the diff?
autobrz is offline   Reply With Quote
Old 11-20-2013, 02:45 PM   #27
White0utFrs
I do not know much about the differential fluid. I will be looking into those threads later. I got mine at RMP in Costa Mesa for 7.something per quart. They have the xl and regular in stock.
Old 11-21-2013, 11:42 AM   #28
pasternak
Drives: Asphalt FR-S
Don't even rev higher than 5k.
Any thoughts would be appreciated thanks!
You need to rev the sh1t out of it more often to loosen it up.
Have some fun for chrissakes ! It's not a Yaris.
pasternak is offline   Reply With Quote
The Following User Says Thank You to pasternak For This Useful Post:
Wes (11-21-2013)
Amsoil sanmarcosfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2013 09:10 AM
Anyone want 0.65 liters of Amsoil SS 0W20? Laika NY / NJ / CT / PA 0 03-31-2013 06:53 PM
Crap. Now I have done it. Apex Chase Scion FR-S / Toyota 86 GT86 General Forum 19 03-16-2013 11:38 PM
Crap, the got me... Mandy Member's Car Journals 4 02-01-2013 02:31 PM
AMSOil distributors in Aust? Panman AUSTRALIA 4 09-18-2012 04:37 AM
